Hemi Swap into a 2nd Generation Ram
Old Jan 13, 2012 | 06:22 PM
  #241
HemiDak-Quad's Avatar
HemiDak-Quad
I think this is it ,
1~ Lock the truck "All doors", Unlock driver door with the key, within 5 seconds turn to unlock position again..
2~ Get in - close all the doors..
3~ Put the key in the Ignition , Turn it ON~OFF- "FOUR times", Ending on the "ON" position , Don't crank engine..
4~ Press the drivers side power door lock switch to lock within 30 seconds..
5~You will hear a single chime when programming is complete and the automatic door locks feature will be deactivated..
6~TO Activate the feature again , follow steps 2~5 again..
I don't know if this will work ~ try it anyway..If that don't work you'll have to contact Dodge and get another Remote Keyless entry...
Old Jan 13, 2012 | 06:25 PM
  #242
DDIRI's Avatar
DDIRI
Yeah If I had nonskim non alarm dash and harness and PDC I think it would. This truck was the top of the line model so it. Came with all the factory security that is really frustrating. My 97 is an Slt but I'm not sure what they have changed in between years. Essentially what I have found out is that with the key in it needs a double pulse to deactivate the alarm. The only way to get that is by doing an aftermarket alarm since the door lock modules went with the donor truck.
Old Jan 13, 2012 | 06:28 PM
  #243
rapidtransitric's Avatar
rapidtransitric
ok. then it might be best to have a professional alarm installer go through things for you. aleast then you can rule that out of the equation
Old Jan 13, 2012 | 06:32 PM
  #244
rapidtransitric
lets see what george has in mind
Old Jan 13, 2012 | 07:11 PM
  #245
DDIRI's Avatar
DDIRI
George always knows what to do it seems. He has done two swaps in the time its taken me to get halfway done with mine. My biggest mistake was buying a donor without keys.
Old Jan 13, 2012 | 07:33 PM
  #246
rapidtransitric
thats usually the the way they are sold. when someone considers a vehicle junk or worthless they could care less about keys a salvage yard has no use for them they don't sell keys
Old Jan 13, 2012 | 07:51 PM
  #247
HemiDak-Quad
And even managed to wreck the first one...Ha~Ha, let me know if that works , I'm out of Ideas ~ unless you want to try Holding you're right hand over you're head and~ Never mind it won't work, Besides it sounds like you have enough pain in the ***** without making it worse ........
Old Jan 13, 2012 | 07:54 PM
  #248
HemiDak-Quad
Not nessisarily true , There are junkyards that sell steering columns "With Keys", But you have to find a junkyard that gives a crap enough to keep the key in it..
Old Jan 13, 2012 | 07:55 PM
  #249
Should be able to figger out what key the pcm wants for the alarm, and then just permanently wire in the correct value resistor to bypass the system entirely.
Old Jan 13, 2012 | 07:57 PM
  #250
HemiDak-Quad
Talk to the alarm dealer if you find an aftermarket alarm.. IF that won't work let me know and I'll send you this 2003 Dash harness..
