Modded Kegger.
Old Jun 24, 2010 | 08:08 PM
  #31
Velocity isn't everything though, you can have high velocity, but low volume, and gain nothing..... or even LOSE power.
Old Jun 24, 2010 | 08:24 PM
  #32
Ugly1's Avatar
Ugly1
True. Volume's not everything niether is velocity. They go together in some way that I'm sure I can't fathom.
Old Jun 24, 2010 | 08:41 PM
  #33
J415's Avatar
J415
Originally Posted by BigRedRam95
How can people say that If they have never tried it
What part of my post gave you the impression that no one tried it and they were just talking out of there a$$? They did, and it was concluded that it's not worth the effort.
Old Jun 24, 2010 | 08:44 PM
  #34
Salex007's Avatar
Salex007
hughes intakes have filled their stage 2 go to their website and see
Old Jun 24, 2010 | 08:50 PM
  #35
Filling the plenum area creates a stronger vacuum signal to the fuel injection. This stronger signal helps to offset the signal lost to large duration camshafts and large port throttle bodies.
And how many of us are using cams large enough to require a boost of the vacuum signal to the PCM?
I will freely admit that I am not an engineer, however, I still don't see how this improves power at all. Looks more like a bandaid to fix a problem introduced with larger cams, instead of doing it the 'right way'™ and fixing it in the tune for the PCM.
Old Jun 24, 2010 | 09:01 PM
  #36
UnregisteredUser's Avatar
UnregisteredUser
It works on the same principle as the Fitch Fuel Catalyst: "I want to perceive a difference so I won't feel like a witless dolt, and by golly I do perceive a difference so I must be freakin' genius!"
Old Jun 24, 2010 | 09:06 PM
  #37
You really need to stop doing that. Do you know how hard it is to get coffee off of an LCD monitor? And I just cleaned it yesterday. Dammit.
On the other hand.......
Old Jun 24, 2010 | 09:51 PM
  #38
1998machz's Avatar
1998machz
well I think I will be staying with the regular volume in my plenum. I have been reading up on this and I think like the others that its alot of work for little gain. That and the fact that I dont know what kind of epoxy to use and how much i need etc. But its been good to see others perspectives on this subject.
Old Jun 24, 2010 | 10:31 PM
  #39
BigRedRam95's Avatar
BigRedRam95
Well I don't know how well it will work. I just talked to a guy that told me it gave him more bottom end and he told me this is his second one the first had no epoxy and he is going to do another one and try something different. I am going to do it and see how it works.
Old Jun 24, 2010 | 10:52 PM
  #40
RamSport97's Avatar
RamSport97
That is quite a bit of work, for very little gain. The epoxy that is. Waste of time IMO.
