My "Rock Solid" Ram Steering Upgrade Experience
Old 06-25-2013, 11:13 PM
PrestonEidsmoe's Avatar
PrestonEidsmoe
PrestonEidsmoe is offline
PM sent. I just checked, my steering is tight. Not sure what the death wobble at the upper speeds or over pot holes is about but, when I get time, I will look deeper. Thanks.
  #62
Old 06-26-2013, 09:06 AM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
I sent you a PM, but it is probably your track bar.
  #63
Old 07-16-2013, 05:46 PM
98Ram5.9Sport's Avatar
98Ram5.9Sport
98Ram5.9Sport is offline
Death wobble can occur from track bar, ball joints, just about anything on the front. I've seen guys replace everything on the front of their Ram/Jeep and still had the dw. Hopefully it is something fairly easy for you.
  #64
Old 07-16-2013, 06:06 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
  #65
Old 12-21-2013, 11:49 PM
rocklong's Avatar
rocklong
rocklong is offline
I have a 2000 cummins manual tranny and can just barely touch the spring when trying to check it for play. The ones u guys did on the trucks must have been gassers or older models? Has anyone done this without removing steering column on a cummins before. If so how did u reach in there to work. I ordered the kit and will be working on this soon. Thanks
  #66
Old 01-20-2014, 12:18 PM
crpunt618's Avatar
crpunt618
crpunt618 is offline
Hey all, I have this same clunking that is described in this thread. I had no idea where it was coming from. I just replaced all my tie rods and upper and lower ball joints last week. I am still getting the clunking noise. But after doing some research and finding this thread I checked the spring on the steering column and it has no play what so ever. My steering is sloppy and I have quite a bit of play before the wheels turn. I would say about a 1/4 turn. I had my gf turn the wheel and it seems the loose steering is coming from the steering box. Can this be adjusted and where else could this clunking be coming from. It usually happens at slow speed while turning and on bumpy roads.
  #67
Old 01-20-2014, 02:42 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,266 Likes on 3,013 Posts
There is a procedure in the service manual for adjusting the steering box, it details a two step adjustment, with the box off the truck...... alternatively, there is an adjuster, and jam nut, right on top of the box, you can try loosening up the jam nut, tightening down the adjuster screw, re-tighten jam nut, and see if its any better. Just go in small steps on the adjuster (1/4 turn).
  #68
Old 05-03-2015, 11:07 AM
IGL1964's Avatar
IGL1964
IGL1964 is offline
Smile Great product
THANK YOU, guys from rock solid, you were amasing in handling an issue of shipping what actual was my sides fault.
I installed the part in my old work truck , 1997 dodge ram 1500 ,5.9l,automatic, 247000 mls and still running great, but i had enough of my steering problems! I almost bought a new steering coloum.
I stumbeld over your site and gave it a try.
Works great feels like almost new.
easy yo install straight forward!!Maybe a little too much paperwork , i know you have to cover your butt from these self knowing all wanna be mechanics . they would might not get it.lol
Anyway, installed in 15 min. with steering coloum installed .
THANK YOU
ASE MASTER CERTIFIED TECHNICIAN
INGO
HIGHLY RECOMMENDED PARTS
  #69
Old 11-02-2016, 09:21 AM
CrayeZ's Avatar
CrayeZ
CrayeZ is offline
Default Measurements?
Just wondering if anyone here took the time to measure one of these ram steering fix bushings? Are the bushings made of polyurethane?
  #70
Old 11-02-2016, 09:24 AM
CrayeZ's Avatar
CrayeZ
CrayeZ is offline
Originally Posted by Silver_Dodge
I have this kit sitting in my garage, never installed. Since I no longer have my '99, anyone interested in it?
I might be interested. Where are you located and how much? pm me if it's still available
Quick Reply: My "Rock Solid" Ram Steering Upgrade Experience
