Kegger Mod (EGR)
I never cut my divider out but I did eliminate the EGR. I just epoxied a plug I got at the hardware store into the hole for the exhaust gas pipe and made a plate to cover the EGR actuator. I rarely get a CEL with the 285/75/R16's I have now but when I had 225/75/R16's it would pop on occasionally on the highway. I have had no other effects.
Why would you remove the center divider anyway? What are you hoping to gain?
More plenum volume for ALL cylinders to draw from. I do believe that later model keggers did NOT have the center divider.
I did the kegger mod to a non-egr manifold to install on my truck, so I could just replace the original. I didn't think mine even HAD egr, until I got the manifold off, and discovered a block off plate. I have never gotten an EGR code. No clue if that was factory, or not.
Once the 'new' kegger was on there, the truck runs MUCH MUCH better, has better low end grunt, more power throughout the RPM range, and I don't have the 'crappy up to 3k, then hang onto your hat' syndrome anymore either. Pulls hard from idle to peak power.
Now, how much of the power gain was from modding, and how much was from fixing my horribly leaking plenum...... I don't know. It was seriously blown when I got the truck.
Alright...I already have My egr Plugged from when I installed my headers . I would just like to know if anyone has cut the center divider out on a plenum that has the egr , because it looks a lot different from this one : https://dodgeforum.com/forum/2nd-gen...egger-mod.html .
Here is Mine...and yes full of oil ! this is after I wiped it with a rag .
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
Trending Topics
