steering gear box stabilizer
Old 11-27-2010, 06:04 PM
dodgeman52's Avatar
dodgeman52
dodgeman52 is offline
Default steering gear box stabilizer
has anybody used a steering gear box stabilizer on there dodge rams?
Old 11-28-2010, 01:01 AM
99dodge318's Avatar
99dodge318
99dodge318 is offline
ive heard of something called the rock ram steering something or another, not exactly sure of its name but it replaces a bushing on the steering shaft
Old 11-28-2010, 09:34 AM
dodgeman52's Avatar
dodgeman52
well i was talkin about the thing that tired the front two frame rails together http://www.carsteering.com/Ebay/ebay...P/88-20100.jpg
Old 11-28-2010, 10:38 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
I don't really know if that would be required for our trucks..... I could see if you were running some fairly large meats, that bracing the box wouldn't be a bad plan..... Not sure if the dodges have the frame cracking issue that the chevy's did.
What size tires ya got on your truck? Do you have steering issues?
Old 11-28-2010, 10:44 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
They mainly keep the pitman shaft from wobbling all over the place. http://www.genosgarage.com/prodinfo....ber=BD-1032004
Old 11-28-2010, 11:13 AM
dodgeman52's Avatar
dodgeman52
i have 315-70-17 guard dog treadwrights and i figured it would help the steering. i thinkin about getttin one of those or dual steerring stabilizers
Old 11-28-2010, 11:44 AM
zman17's Avatar
zman17
zman17 is offline
I assume you have checked all the steering components for play?
Old 11-28-2010, 11:46 AM
dodgeman52's Avatar
dodgeman52
yea everything is tight it just seems like after i got the 315s it seems like the tires want to jurk the wheel around when i hit a small hole in the road and also some times it like to wander when going down the road
Old 11-28-2010, 02:32 PM
HeyYou is offline
Bump steer. Neither symptom really indicates a problem though, fairly standard with big tires. An alignment might help some, but, I wouldn't hold out a lot of hope. The brace may also help, to an extent, but, don't expect to completely eliminate either condition.
Old 11-28-2010, 04:18 PM
dodgeman52's Avatar
dodgeman52
alright then i was thinkin about trying it cause i can get one for around 80 dollars
Quick Reply: steering gear box stabilizer
