truck shakes when it shifts into OD(4th) and more NEWBIE questions
Old 12-08-2010 | 01:32 PM
vikingdiesel's Avatar
vikingdiesel
Ok well I just ran the diagnostics, seems the check engine light doesn't work, I got 2 codes,
P0207: injector circuit open cylinder 7
P0307: cylinder 7 misfire
So what does this tell me , bad injector? I'm getting it checked today for flow rate
  #52
Old 12-08-2010 | 01:49 PM
Either the injector on number 7 is bad, or, the wiring to it. Swap the number seven injector with number 5. See if your miss moves with the injector or not.
  #53
Old 12-08-2010 | 02:47 PM
vikingdiesel
What's the cylinder order, need pics
  #54
Old 12-08-2010 | 02:57 PM
from front to back:
Drivers Side: 1,3,5,7
Passenger side: 2,4,6,8
  #55
Old 12-09-2010 | 08:35 PM
vikingdiesel
THANKS ALOT GUYS, yes, the (2) wires for INJECTOR #7 were completely cut and I fixed the wires and the truck drives great!!
  #56
Old 12-10-2010 | 07:32 PM
Dantra's Avatar
Dantra
Suweeet.
  #57
Old 03-04-2011 | 03:01 AM
Gspot750's Avatar
Gspot750
Ok guys! I'm having the same issue with my 95 1500 5.2L. So when I bought it the guy at the dealership said u- joints... Wrong. So I read this forum and gave tune up.... Nope, and now when I start the engine it idles high and the brake is super stiff, I can barely stop. Any ideas!!!
  #58
Old 03-04-2011 | 04:26 AM
Gspot750's Avatar
Gspot750
UPDATE:
Idle and brakes are good.. It was a vacuum leak, aka a hose popped off. More importantly the truck still shakes when overdrive kicks in at slower speeds. Can't remember if previously mentioned by someone else but if I press OD button mid-shake it stops.
I'm slowly turning into a gearhead.....
  #59
Old 03-04-2011 | 08:58 AM
You still have a miss there somewhere. when you did the tuneup, what all did you replace? Have you had a look at your plenum yet?
  #60
Old 03-04-2011 | 01:55 PM
Gspot750's Avatar
Gspot750
I replaced plugs, wires, cap, rotor, (btw this is not user friendly placement, but it was fun). I have not looked at plenum yet.
What other signs would point to plenum?
Quick Reply: truck shakes when it shifts into OD(4th) and more NEWBIE questions
