End-all Be-all plenum thread
Old Feb 22, 2020 | 11:41 AM
  #1101
Twmays's Avatar
Twmays
About 1.2 hours it's a pretty simple job. Hardest part was the fuel disconnect, it didn't want to disconnect lol. I also meant Cloyes Double Roller timing set.
I cant even find all the tools i need in 1.2 hours...
When I did mine about 6 or 7 years ago, it was 2 or 3 days, 4-6 hours a day. Maybe could have gone a little quicker if it wasn't the middle of January and temps would have been above 5 degrees.
I did the plenum, the thermostat, the water pump, the timing set, plugs, wires, cap, new hoses, new belt, etc.etc. Basically any wearable or soft part that had to come off, I replaced when reassembling.
I also installed a remote start at that time, but that's not included in the time quote above. Ah, to be young and dumb again.
I remember one of the most time consuming parts was actually getting the fan shroud up and out without breaking it. Brittle plastic tabs that don't want to let go when they've been in place for 20 years.
Old Feb 22, 2020 | 01:36 PM
  #1102
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The hardest thing I ran into was painting everything lol
Old Mar 11, 2020 | 01:41 AM
  #1103
kody hohstadt's Avatar
kody hohstadt
Default 95 1500 5.9 v8 two wheel drive laramie
Been scanning and scanning and I can't seem to find anything on a thicker steel plenum plate. I know it will expand different and such but has anyone tried making a1/4 steel plenum yet? Also props to you dot guys on making you're own. I think I'm gonna take it a little overboard and see if I can smelt down a bunch cans and make a sand cast of original plate and a foam cutout 1/4 thick and Wallah plenum plate made. First though gotta diy a foundry. Gonna be fun
Old Mar 11, 2020 | 07:58 AM
  #1104
I haven't seen a steel one. Lots of aluminum though. Same material the rest of the manifold is made of.
In all reality, you don't need either though. Use the stock steel plate, a GOOD quality gasket, and shorter bolts. End of Problem.
Old Mar 11, 2020 | 11:04 AM
  #1105
MoparFanatic21
I even welded mine together for peace of mind
Old Mar 11, 2020 | 01:13 PM
  #1106
Probably overkill, but, you know for a FACT it will NEVER leak again.
Old Mar 11, 2020 | 04:26 PM
  #1107
MoparFanatic21
Exactly, it will NEVER leak again, which is what I wanted plus got to teach my cousin how to weld aluminum
Old Mar 18, 2020 | 07:19 PM
  #1108
kody hohstadt
One more question probably not a vary smart one but ware do I put this little o ring that came with gasket kit?
Old Mar 18, 2020 | 08:22 PM
  #1109
MoparFanatic21
on the pipe coming out of the waterpump
Old Mar 20, 2020 | 12:04 AM
  #1110
Sledder10's Avatar
Sledder10
I'm sure it's in the thread somewhere but what's the consensus on using ultra black along with the gasket on the repair? Last two repairs I have done (different rigs) have failed reusing the stock plate, shortening the bolts, and using a good gasket along with ultra black. I splurged on the Hughes kit for the latest fix, and they included a tube of ultra black so I did a little research. Both felpro and permatex websites said explicitly do not use an rtv along with the gasket, dry is fine, at most use a sealer. Ended up just putting the gasket on dry, figured what the hell, what I was doing wasn't working.
