End-all Be-all plenum thread
Old Jun 12, 2012 | 11:05 AM
  #431
Gary-L's Avatar
Gary-L
Veteran: Navy
You can disconnect the fuel line from the rail, and just leave it in place. Careful with it though...... if you break it, they are fun to find.
By "fun" don't you mean "a royal pain in the ***"?
Old Jun 12, 2012 | 11:12 AM
  #432
crazzywolfie's Avatar
crazzywolfie
my 93 has hose clamps and rubber line in the frame. don't know if that is how it was suppose to be but it seem work.
Old Jun 12, 2012 | 12:56 PM
  #433
BamaRam97's Avatar
BamaRam97
I would put my money on this. Not to mention I have the dreaded 97 fuel line made of composite/plastic. I've read through several threads, but if anyone has any advice on taking the valve apart I'd be open to it. I can't see the FSM at work, but I'm sure it's detailed there too.
Old Jun 12, 2012 | 06:15 PM
  #434
1999blkdakrt's Avatar
1999blkdakrt
Sure you just pry the lock up with a screwdriver, it pops up really easy, then you just pull the fuel line out, it is alot better than the other male end fuel rail, don't worry, I got access to about 4 or 5 more, just helped out a member HEY YOU referred to me.
Old Jun 13, 2012 | 08:22 AM
  #435
BamaRam97's Avatar
BamaRam97
I was able to get that connection loose very easily, nothing to it. I'm think you are the guy I just bought the plenum plate from off ebay. I'm looking forward to strapping it on this weekend and not dealing with the plenum problem anymore! Thanks bud!
Old Jun 13, 2012 | 10:26 AM
  #436
1999blkdakrt
Same name. Amazing results.
Old Jun 13, 2012 | 04:15 PM
  #437
It's Me Patt's Avatar
It's Me Patt
no need to be hostile just be aggressive..and new members like myself don't know every inch of the forum off the bat. with that said thanks to all for the great info...from Matt who posted the thread link for me too the man scientist!
Old Jun 18, 2012 | 10:48 PM
  #438
5.9ramrod's Avatar
5.9ramrod
On page 13 the discussion turns to the rotor position under the dist. cap, is the rotor supposed to be pointing at the number one cylinder? or the number one cylinder (plug wire terminal on the dist. cap?
Old Jun 18, 2012 | 10:51 PM
  #439
Depends on what you are doing. If you aren't touching anything timing related, then it doesn't matter where it is. If you are doing timing chain and gears as well, just pull the timing cover, turn things so the dots on the gears line up, take off the old, put on the new, WITHOUT MOVING ANYTHING, and you are down the road.
Old Jun 19, 2012 | 02:12 AM
  #440
5.9ramrod's Avatar
5.9ramrod
I also remember when I bought the dist cap, rotor, plugs, and wires the guy at Advance said the rotor needs to be pointing to the number one. I didn't think much of it at the time or when I changed it out, you're saying this isn't the case?
