46RE Transmission Problem
#21
Steel Module
Can anyone tell me what the "steel module" is on this list? I want to order the parts to rebuild transmission, but cannot find this item in the manuals that I have and the websitre does not include a picture. I want to make sure I have everything I need (and hopefully understand what I am doing). Is the steel module and the friction module combined the disks for the clutches?
Thank you.
[/quote]
Thank you.
[/quote]
#22
#23
#24
So while I am waiting on tranny parts, found intake at salvage to do kegger mod after the transmission work is done. First glance it appeared that I got probably the only one without the plenum gasket blown out (from photos posted on this forum).
Pulled pan and guess what?
Attachment 13690
Looks like it was leaking. I would not have known anything about this without postings from you guys. Thanks.
Attachment 13690
#25
Planetary question
So I bought a pair of 6 gear planetary sets. I pulled down the OD unit today and am starting back together and just had something strike me. The planetary set in the OD is a 3 gear set. Will this create a problem or is this OK? I checked several places (including WITTRANS) and did not see a 6 gear set for the OD.
Just wanted to check before I screw up.
Thanks.
Thanks.
#29
Trouble pressing OD clutch hub
I am trouble pressing OD clutch hub. I got about 9/16" and it started to bind as hub was slightly cocked. It galled slightly on the internal spilnes on the hub.
I had to use a harmonic balancer puller as I do not have access to the special tool for this.
Anyone have any suggestions how I can get this straight? I am going to use a jeweler's file to remove burrs.
Thank you.
Thank you.
#30
