Forced to down grade 06 to 98
Old Aug 6, 2011 | 09:29 PM
Vader's Avatar
Vader
Default Forced to down grade 06 to 98
Well due to circumstances beyond my control, I gave my 06 Ram to my Dad and ended up getting a very high mileage 98 1500 4x4 5.2 Ext cab with a mint body and interior.
Turning into a daily project truck.
So far,
ABS/Brake light is on, new speed sensor but still on.
Reverse lights work but do not come on.
Steering wheel makes a rubbing sound while turning.
May need heater core soon, carpet dry but a little smelly interior
Rear main seal leaks.
HeyYou has been helping me on a daily basis but I will probably be asking for assistance on a regular basis.
Old Aug 6, 2011 | 09:41 PM
dhvaughan's Avatar
dhvaughan
welcome to the dark side.
most likely speed sensor in the top of the rear diff, called rear abs sensor.
neutral safety switch, drives side of trans, near the front.
probably inner column bearing, avail at dealer.
heater core is a bitch.
rear main is 2 piece, not that bad. see pavementsucks' tech articles.
Old Aug 6, 2011 | 09:42 PM
He has 4wal though I do believe.
Old Aug 6, 2011 | 09:46 PM
Vader's Avatar
Vader
Can't seem to locate neutral safety switch. Is it located on the top of the tranny?
Old Aug 6, 2011 | 09:49 PM
dhvaughan's Avatar
dhvaughan
not on top.
drivers side - down low, hiding behind/right in the middle of, the linkage. has an electrical connector thats hard as hell to get your fingers onto.
Should be right where the shift linkage hits the trans. its own separate connector. If you have the manual, they have a nice pic for ya.
Old Aug 6, 2011 | 09:51 PM
dhvaughan's Avatar
dhvaughan
oops. do our trucks have an ABS diagnostic port/flashing light thing that blinks a code for where the fault is.
Old Aug 6, 2011 | 09:52 PM
I don't know.... I always just used the snappy scanner for such things......
Old Aug 6, 2011 | 09:53 PM
lastrights's Avatar
lastrights
Welcome !
Old Aug 6, 2011 | 09:55 PM
Vader's Avatar
Vader
That would be nice!
