gaaahhhhh this cant be happening
Old Sep 18, 2011 | 08:36 AM
  #41
at one time, there was a thread from a member that was getting ready to do the plenum repair.... and he collected a pretty complete list of things he wanted to do, parts he would need, etc. He was also doing water pump, and timing chain. I can't come up with the thread just off-hand here..... but, that would be a good one to peruse.
I agree with doing the timing set as well. I think that one repair did more to perk up my truck than anything else. The difference was really amazing. I got the SA double roller set from advance auto for about 50 bucks. Nice quality piece.
Just doing the water pump at this point pretty much assures that in the not-so-distant future, you are going to have to reseal the front timing cover.... so, while you are RIGHT THERE anyway, pull that feller off, it's only a few more bolts.... reseal it, and replace timing set. You won't regret the exercise.
Old Sep 18, 2011 | 10:07 AM
  #42
beefythedodge's Avatar
beefythedodge
he def has a point there. is always wise to take that preventative measure step while you are that close. do it to it!
Old Sep 18, 2011 | 02:02 PM
  #43
redneck_ram's Avatar
redneck_ram
think im going to go with the sa gear double roller from advance. how good is it?
Old Sep 18, 2011 | 02:14 PM
  #44
redneck_ram
oh, im going to do the plenum while im in there too! ive had the hughes kit since february.....
Old Sep 18, 2011 | 03:26 PM
  #45
lastrights's Avatar
lastrights
you should see a nice power inprovemnt switching out your chain and doing plenum with the amount of miles on her
Old Sep 18, 2011 | 04:27 PM
  #46
redneck_ram
Ok so i just left advance and they have everything in stock except for the double roller timing set. The guy i talked to suggested that i go with just a stock replacement because it would do fine for what i use my truck for. What is everyones opinion here, double roller or stock replacement and why.
Old Sep 18, 2011 | 06:20 PM
  #47
lastrights's Avatar
lastrights
go stock if you dont think you will have it for 40 k more miles. the stock chain wears out pretty easily
Old Sep 18, 2011 | 06:36 PM
  #48
The morse style chains (stock type) are rather prone to stretching, and quite frankly, I just don't like 'em. Not like you want to do this tomorrow anyway right? They should be able to get one in a day or three. Go with the part you want, not just one "that'll work"....
Old Sep 18, 2011 | 07:28 PM
  #49
redneck_ram
already bought the stock replacement. didnt feel like waiting a few days for the part, so i just got what they had in stock. got everything i needed. just gotta go to the stealership and get the new intake manifold bolts so i can do the plenum too.
Old Sep 19, 2011 | 07:48 PM
  #50
redneck_ram
little update for today.... went to the dealership and got the intake manifold bolts. got the front end of the truck all apart. just gotta get the clutch fan off then everything can start coming apart. hopefully the rain holds off.
