I dont mind doing my own work if i knew what i was doing. Ammco offered a free check. This was before all this happened. I dont mind changing the solenoid myself i saw them when i did the srevice. Really not sure about the band adjustment.
Adjusting bands is not difficult -just follow directions in factory service manual that is in the DIY section. Use a torque wrench, do it right. If this is the extent of your problem, it will save you some money. Check for debris in the pan when you drop it. Use AFT 4 - nothing else to refill. No additives or other snake oil.
sorry to bug AGAIN but, i noticed the trans cooler lines do not go into the rad. it has a smaller cooler in front of it. Is this the right set up? The rad does have ports for the trans lines.
It looks aftermarket. It has the 2 lines coming from trans to a rubber hose going to the cooler with hose clamps. It like a 1' x 1' cooler the is mounted to what i believe the ac condenser? I didnt try the tire switch. Kinda nervous with trans acting up. I did try to back it up and it bucks. Does go away but when you let off the gas feels like you put the e brake on. Neutral it rolls around fine.
