Is it just me or do Dodge's 2nd Gen's front ends suck ***. I recently replaced everything on my front end because everything was either bad or lose. I recently lifted my truck also. I have noise in my front end once again. Question is, could this be from the control arms? Since they are now pretty much maxed out? Also, could it be because I have stock length shocks on there? Or could it just be because of the coil spacers? I have no idea maybe I didn't tighten the traction bar enough when I put the front end back together after putting the lift on. I am not sure. But I would love to hear what you guys have to say about this.
Other than neglect and wear when I bought the truck, which I promptly remedied, my front end now works great with no noise, no slop, and no problems. Modifying the design by lifting kind of removes the responsibility from "Dodge's 2nd Gen's front ends suck ***"....... imho.......
Noise could be coming from a number of places. Is it suspension realted or drive related? Gringing, rubbing, squeaking, or popping? Did you relace bushinigs on suspension as well?
When I hit any type of bump going down the road. I don't know how to explain the noise... Idk it just sounds like something is moving without a bushing inside it it's like a thud, thud, kind of noise. Its hard to explain I wonder if I could record it..
Take a look at control arms and all bnushings on all of the suspension parts. Also check to make sure you aren't banging the shocks at the end of the stroke, as well as shock bushings.
I would not be surprised if it was the control arms. Because the bushings look shot and whenever the axle moves up that's when I hear a thud then when it drops back down I hear another.
I recently lifted my truck also. Or could it just be because of the coil spacers?
Originally Posted by EvanBoothe123
I replaced all tie rods and yor rod end and a new trac bar. I didn't replace control arms or the bushings in them
Did you put everything to proper torque specs? Especially the track bar. How much was the lift and my what means (e.g, spacer, suspension lift)? The assumption is that you have the right length of track bar for the lift. They change if > 3" of lift, which also modifies other components like pitman arm. What track bar is it anyways?
Find an actual speed bump as a better test of environment.
