no fog lights new radio?
#32
#33
Bought myself a transfer pump, so im going to do my transfer case ATF4 fluid and an oil change. Also going to clean my throttle body. while im doing this i will pull the steering column cover and see if theres something else that neds to be removed to get to the switch. than ill take a look at the wires
#34
#35
i have a Haynes! I have a 2001 downloaded dodge ram service manual! (all though i have a 98) and I know how to GOOGLE! thats how i did my timing chain gasket, and with this here forum ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Also i bought the transfer pump to put the fluid IN my transfer case. last time i had to put a tube into the bottle of the ATF4 and tape it than kinda squeeze it into the transfer case. Boy was that a mess lol.
#36
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
#38
just wanted to keep posted still havent pulled the dash to do vac leak and check the switch for the speedometer lights and fog lights but this just in......
yesterday i put in a bigger battery that was brand new and redid the ground wire. i also took the two relays and swapped them in the pcm with each other making sure to press down and get them all way in. i turned the truck on (it started quicker) anyways the lights still didnt come on. thats was yesterday today my wife was pulling in our drive way and I looked out the window. dem sum bitches were on! intrigues me to see if they stay that way...
