changed header gasket now no start
Old 01-25-2012, 12:04 AM
J415's Avatar
J415
J415 is offline
HeyDrew, I heard that header wrap actually retains water and causes rust.
  #192
Old 01-25-2012, 12:10 AM
drewactual's Avatar
drewactual
drewactual is offline
This may be a good thing.. it will give me reasonable excuse.. I paid over three bills for those trash hedman headers.. I was told they were the only ones that worked on the cali rig.. I was lied to. For the money I've spent on gaskets and fasteners, I could have bought two sets of ebay headers that are just as good..
I almost hope to.discover cracks or bends.. I just can't bring myself to give up on them yet, even though its unreasonable..
The remflex and stage 8's are the last stop before they join hoffa..
But, yes, wrap can cause rust.. bit it keeps the bay cooler, and more importantly, the exhaust stream warmer.. imah give it a shot to see..
  #193
Old 01-25-2012, 12:15 AM
mstephen89's Avatar
mstephen89
mstephen89 is offline
i like the coil idea, try it, if it doesn't fix it just put the other one back on, and have a spare, cause it will be needed one day.
  #194
Old 01-25-2012, 01:20 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Originally Posted by 2x1972
MORAL OF THE STORY EVERYONE:
Don't change your header gaskets.
  #195
Old 01-25-2012, 02:08 AM
J415's Avatar
J415
J415 is offline
Originally Posted by BackwoodsRam
I don't have an ohmmeter, but a few months ago I checked just for S's and G's and it was right at the limit for max ohms
Well, eveything, at one point or another, works. The question is, does it work now. An ohm meter can be had for as little as $10 (harbor freight model).
  #196
Old 01-25-2012, 08:53 AM
gertie240's Avatar
gertie240
gertie240 is offline
+1 on the multi meter, even W--mart carries some. totally need one in the tool box
  #197
Old 01-25-2012, 12:20 PM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
The sad thing is i'm an electrician but all my fancy tools are at work lol
  #198
Old 01-25-2012, 12:45 PM
BackwoodsRam
Hey I can't get to my service manual right now do can someone please tell me what the coil is supposed to ohm out to? Pretty please with cherries on top and by cherries I mean hookers and blow
  #199
Old 01-25-2012, 01:00 PM
BigBlue83's Avatar
BigBlue83
BigBlue83 is offline
i couldnt find it in the service manual however i checked out the haynes for you this is what is says:
ignition systems
coil
v6 and v8 engines
Diamond
Primary resistance.......... 0.97 to 1.18 ohms
secondary resistance.......11,300 to 15,300 ohms
Toyodenso
Primary resistance..... 0.95 to1.20 ohms
secondary resistance... 11,300 to 13,300 ohms
hope that helps good luck
  #200
Old 01-25-2012, 01:01 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Ok, two different manufacturers of coils...... (from the 01 manual.)
both are pretty similar though, basically, Primary circuit should be around 1 to 1.2 ohms. Secondary circuit should be around 11,300 to 15,300 ohms. (13,300 for the toyodenso coil.)
Edit: Ninjaed!
Quick Reply: changed header gasket now no start
