Thats why the limited slip doesn't work anymore
Old May 25, 2012 | 05:44 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 99ram360sport
well i wanted to regear anyways i guess. I priced everything and im looking at
$750 for an auburn lsd
$300 for 4.10 ring and pinion
$320 for master install kit
$300 shop labour
So it will not be happening right away, but i wiil do it as soon as i have the money
thats some crazy pricing....I got my Yukon master install kit for like $150...and another 150 for the rebuild kit for the factory lsd..... with labor everything was somewhere between 600-700 I think but not sure...
this is the kit I used I think...
http://www.ebay.com/itm/CHRYSLER-9-2...ecdff2&vxp=mtr
here's an auburn for much less...(used though)
http://www.ebay.com/itm/Dodge-9-25-3...e9a30d&vxp=mtr
Old May 25, 2012 | 05:55 PM
Wombat Ranger's Avatar
Wombat Ranger
Does anyone run G2 gears and if not has anyone heard anything bad about them? My choices are G2, Motive gear, Richmond,
G2 is the cheapest motive is in the middle and Richmond is very expensive.
Those are all great gear manufacturers. I am getting Motive's for mine when I do the job, but that's because they are the cheapest high quality set I can find. Go with the G2, save some dollars.
Old May 25, 2012 | 07:53 PM
From what I can find in a brief search, they aren't too bad. Most folks have no complaints. One guy shattered the ring gear, but, he was doing hard wheelin' every weekend too......
Old May 25, 2012 | 08:14 PM
Wombat Ranger
Are you talking about the G2's? That's interesting to hear. Was he running large tires and big power? I assume so. Unless it was a freak thing with a flaw in the manufacturing of the ring gear?
Old May 25, 2012 | 08:22 PM
99ram360sport's Avatar
99ram360sport
Thanks hey you, i dont do any hard wheeling in my truck as it is my Daily driver and in the past i have found that it only ends up costing me money.
Old May 25, 2012 | 08:25 PM
crazzywolfie's Avatar
crazzywolfie
is it worth having a LSD that is working? how important is the friction modifier? there is a tag under the hood on my ramcharger that say something about a limit slip differential. i can just tell by the blues sealant on the rear differential that someone has been in there and every time i find stuff that has been done it never seems right.
Old May 25, 2012 | 08:30 PM
99ram360sport
^^^ I am going to be changing the ring and pinion because it is missing a tooth and possible some chips out of it, however to do this i am also going to have to get a new carrier because the chunks of clutch left some marks in so i figure i might as well get an auburn LSD while i am at it and be done.
Old May 25, 2012 | 10:06 PM
I think the truck that blew them apart had a rear D44, behind a V-8, and 37" tires...... Combine that with hard wheelin', and it isn't really surprising he blew them apart.
If you have an LSD, you WANT that friction modifier in there. Otherwise, you eat clutches, and it turn itself into an open rear.... at best....
Old May 25, 2012 | 10:20 PM
crazzywolfie
good to know. that is now on my list of thing to do which is getting longer with the more time i spend here.
Old May 25, 2012 | 10:50 PM
mccart's Avatar
mccart
Nitro gear is also a good brand. Go to justdifferentials.com
