Thats why the limited slip doesn't work anymore
Old May 25, 2012 | 03:01 PM
99ram360sport's Avatar
99ram360sport
Default Thats why the limited slip doesn't work anymore
I changed the rear diff fluid and found these pieces laying at the bottom. Most of them are parts of the dodge limited slip and one happens to be a tooth off of my ring gear. There are no noises from the diff when driving, so i have no idea when it happened.
http://s1267.photobucket.com/albums/...t=DSCN4053.jpg
Old May 25, 2012 | 03:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A little searching here on DF will tell you that's a fairly common problem.
Old May 25, 2012 | 03:20 PM
Where on the ring gear is the broken tooth from??
Old May 25, 2012 | 03:29 PM
99ram360sport
Not sure Hey you, i had a shop change the fluid and they gave me the pieces and just said that the tooth was off my ring gear.
Old May 25, 2012 | 03:36 PM
Augiedoggy's Avatar
Augiedoggy
yup...I had the same pieces before my rebuild... even the shop told me it was common...
Old May 25, 2012 | 03:49 PM
99ram360sport
well i wanted to regear anyways i guess. I priced everything and im looking at
$750 for an auburn lsd
$300 for 4.10 ring and pinion
$320 for master install kit
$300 shop labour
So it will not be happening right away, but i wiil do it as soon as i have the money
Old May 25, 2012 | 03:54 PM
Wow, they are pretty proud of those parts..... r&p can be had for less online, install kit as well. (like, 300 bucks for both......) not much you can do about labor, and the LSD.
Old May 25, 2012 | 04:20 PM
mccart's Avatar
mccart
You can get a Yukon posi for about 350 and the install kit for about 100.
Old May 25, 2012 | 04:24 PM
99ram360sport
^^^^ i live in canada so parts are always more than they are in the states. I have been on websites such as summit and others and have seen much lower prices on ring and pinions however by the time i ship it and pay duty at the border they end up costing as much as they are up here.
And believe it or not those are discounted prices on the parts The retail on the LSD was $1059, the r & p was $450 and the install kit was $399
Old May 25, 2012 | 05:23 PM
99ram360sport
Does anyone run G2 gears and if not has anyone heard anything bad about them? My choices are G2, Motive gear, Richmond,
G2 is the cheapest motive is in the middle and Richmond is very expensive.
