Valve Timing Questions
Old Sep 20, 2012 | 09:05 AM
  #211
MeanMagnum99's Avatar
MeanMagnum99
Make sure the dist isn't slipping in the clamp as well. Scribe some alignment marks when you get it set again, and see if the dist is walking.
It's hard to see back there without my mirror but I will make some marks the best I can with my fine point Sharpie pen. I think when I painted my dizy before I put it back in after the cam install was a bad idea. I bet the paint is getting hot and letting the clamp slide.
Old Sep 20, 2012 | 04:24 PM
  #212
MeanMagnum99
Here are some pics of the stuff I've done to my truck for everyone that asked for pictures.
http://s1153.photobucket.com/albums/p509/MeanMagnum99/
Old Sep 21, 2012 | 10:39 PM
  #213
aim4squirrels's Avatar
aim4squirrels
Are you using a tool to tighten the hold down clamp that is rubbing against the disty housing? I remember you telling me you weren't using a disty wrench. If it's some sort of socket, it might be walking the disty around while you are tightening.
I used to loosen it only so that I could just twist it with a firm grip. The amount of movement is so minute, just a small bump can send it 4° off the original setting. If the clamp is too loose, even the tension from the spark plug wires can twist it off where you set it.
A lot of slack in the timing chain or weak valve springs can also make it hard to get a handle on the actual fuel sync setting, but I think you've taken care of all that stuff.
Old Sep 21, 2012 | 10:51 PM
  #214
MeanMagnum99
I used to loosen it only so that a could just twist it with a firm grip. The amount of movement is so minute, just a small bump can send it 4° off the original setting. If the clamp is too loose, even the tension from the spark plug wires can twist it off where you set it.
I have been using a ratcheting wrench with a head that can bend up to 90°the either way. So far it's staying so my fingers are crossed lol And yes, anything to deal with slack should have been taken care of. I have the JP set you recommended and fully built heads with all new performance valves and hardware. I'm not proud to say how much I've got in the top end of this truck alone lol The money tree in the back yard was stripped and died a few weeks ago haha
Old Sep 21, 2012 | 11:03 PM
  #215
aim4squirrels
That wrench is what I'm wondering about, if the round outer part of the wrench butts up against the distributor housing right down at the baSE, the housing could be turning the opposite way of the wrench as you tighten.
Do you have a set of open end wrenches that can do that same 90° swivel at the end?
Old Sep 21, 2012 | 11:06 PM
  #216
merc225hp's Avatar
merc225hp
A crowfoot wrench work's as well with a extension.
Old Sep 22, 2012 | 10:57 AM
  #217
MeanMagnum99
I thought the same thing and while its on the bolt I had about a 1/4" of room between the outer edge of the wrench and the housing. I'm thinking I wasn't getting it tight enough and the paint was acting as a lubricant when it would get hot. It's been 2 days and she's still at +2. Maybe she's gonna stay now lol
Old Sep 22, 2012 | 04:27 PM
  #218
MeanMagnum99
It moved again today. I'm seriously thinking the sensor is bad. It does have 100,000 miles on it so I'm sure its overtime to be replaced.
Old Sep 22, 2012 | 05:21 PM
  #219
dlyter09's Avatar
dlyter09
Well hopefully you get it figured out.. Im nominating you for the October ride of the month lol.. you have a good looking truck man
Old Sep 22, 2012 | 06:32 PM
  #220
MeanMagnum99
Yeah I do too. I really think its my original cam sensor that's just getting old and loosing signal. Thanks for the nomination bud, I didn't even know they had rides of the month lol
