Won't rev past 3k rpm?
98 5.9 gas, all stock expect for headers, only 150 miles on rebuilt motor.
So its been doing this ever since i put the motor in. It was running rough, and drinking ALOT of gas. and at first i just thought it was a timing issue. The timing was fine, so i found out it had a bad injector. Now it idles and runs just fine, but still seems kinda low on torque and will not rev past 3k rpm.
No cels or anything either, what the hell!
And the exhaust is hooked up and the cats and o2s were fine before swap
"What do you mean in the correct orientation? and fuel sync?" That answers part of the issue. http://www.bionicdodge.com/Download/...uel%20Sync.pdf
But the motor idles and revs fine all the up to 3k, then i just stays there and wont rev any higher
Trending Topics
