Cracked Dash
RE: Cracked Dash
It's a common problem with all 2nd generation Dodge Rams. [:'(]
www.genosgarage.com supposedly has the best replacement for it. It sounds like it isn't a fun job changing it though. I have to do it sometime in the future, but it's not first on my list.
RE: Cracked Dash
ORIGINAL: pasport4x4
Just noticed my 2001 Sport 4X4 Ext Cab that I bought 2 months ago has a
pretty good crack in center dash and 1 about steering wheel area. All starting at the window.
Is this a known problem with this Model or Make? If so any ideas to control the
crack? Thanks
crack? Thanks
Here's another thread that you can check out and see how others are fixing/replacing there's:
https://dodgeforum.com/m_196287/mpag.../tm.htm#196287
Good luck
Trending Topics
RE: Cracked Dash
my actual dash inst cracked but the trim bezel that goes around the face of the dash... the one that you just pull off is got a ***** missin and its cracked... im talkin about the bezel that sarounds the gageus stereo cubby hole light switch... cant find a new one either... any hints?
