Emission Test Failed ! (California smog) - All Other Pass. 95 Ram 1500
Old Mar 7, 2014 | 11:54 PM
  #41
bosanci28's Avatar
bosanci28
Originally Posted by Ram Driver
You havn`t changed your oil in 15000 miles ?, not a good way to take care of your engine. What about cap rotor and plugs ?.
You referring to me or other user? (my oil was changed 2900 miles ago).
Old Mar 8, 2014 | 12:08 AM
  #42
bosanci28's Avatar
bosanci28
Update on work done till now:
Changed:
*Oil filter > Wix oil filter brand (oreilly auto parts-$7.50)
*Oil > Castrol GTX HM 10W-30 (5qt Jag) & Bosch Oil Filter (autozone-$24)
*PVC Valve (from stealers-$12)
*O2 Sensor NGK (riebes auto parts/Napa-$56)
*Di-Electric grease compound (Autozone - $9)
Still working on other things tomorrow, like @Wh1t3NuKle said in post #27
Then Monday will take the road up-hill for about 20 miles and then comeback down for other 20 miles
so thats 40 miles and will go straight to smog to see what will happen.
Any other things that i should maybe check?
Thanks for advice!.
(Where will be the cheap to buy the complete set to do the plenum ? - need to do some research on this, i think very
soon will have to get this too,and do it.)
Old Mar 8, 2014 | 12:28 AM
  #43
Ram Driver's Avatar
Ram Driver
Check here, they have a complete plenum kit with everything needed to do the job.
http://www.hughesengines.com/Index/p...e&partid=27091
Old Mar 8, 2014 | 09:58 AM
  #44
sumone's Avatar
sumone
Try early AM (humidity), below 50 deg F (humidity), inflate the tires
(Calif). Remind myself, oil is to expensive at autozone. Best of luck!
Old Mar 8, 2014 | 10:29 AM
  #45
bosanci28's Avatar
bosanci28
Thanks for the link!
Old Mar 8, 2014 | 10:31 AM
  #46
bosanci28's Avatar
bosanci28
Thanks for that advice!.
Oil and filter was $24 at autozone, my bad i put the total of the hole receipt including that
Di-electrical grease.
Thanks.
Old Mar 8, 2014 | 12:26 PM
  #47
You can also get just the plate from EBay, and source the gaskets locally. I don't care for the gaskets that hughes gave me with the plate. (save a little money that way too.)
Old Mar 8, 2014 | 12:55 PM
  #48
bosanci28's Avatar
bosanci28
Hmm, i did not see one on ebay... under "plenum"
and i see at hughesengines the complete set is $119 or just the plate and bolts for $93,
so if you buy the $93 one with bolts and then get all those gaskets,hose,etc will get around there also? around 119 ...
Old Mar 8, 2014 | 01:06 PM
  #49
I think the gasket set/bolts runs around 30 bucks or so. The Ebay plate is I think 60, with the bolts. The guy is a member here, but, for the life of me I can't remember his name. He may be out of stock at the moment.
Old Mar 8, 2014 | 08:06 PM
  #50
Arde's Avatar
Arde
http://www.ebay.com/itm/200942695172...S:3160&vxp=mtr
I can't remember his name either but think his wife actually sells them. They come with plenum pan bolts, but you'll have to buy new manifold bolts and an intake manifold gasket set at an auto parts store.
woops, just took another look, ended July 23, '13. Might be SOL except for Hughes.
