Emission Test Failed ! (California smog) - All Other Pass. 95 Ram 1500
http://www.ebay.com/itm/200942695172...S:3160&vxp=mtr
I can't remember his name either but think his wife actually sells them. They come with plenum pan bolts, but you'll have to buy new manifold bolts and an intake manifold gasket set at an auto parts store.
woops, just took another look, ended July 23, '13. Might be SOL except for Hughes.
Yes, i will contact to see if they still do have a complete set ,as i see that they had with $90 complete set.
http://www.ebay.com/itm/DODGE-JEEP-ALUMINUM-PLENUM-PLATE-BELLY-PAN-318-360-5-2-5-9-MANIFOLD-REPAIR-KIT-/190885191868?vxp=mtr&nma=true&si=7mueZsylcSX9A3iez%252FtxC3hqLBw%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Also i got this today:
Vacuum Tester for Harbor Freight
http://www.harborfreight.com/fuel-pu...l#.UxvR3BxRTYo
Was hoping to do a test to see ,what will it show ,like results.
How to video:
And some pdf guide:
http://dodgeram.info/tsb/2000/09-05-00.htm
Thanks.
How to video:
And some pdf guide:
Thanks.
1999BlkDakRT is the seller... http://www.ebay.com/usr/1999blkdakrt
I bought mine from him in January, so I know he had some then.
I got that and the Dorman kit off rock auto, which came with all bolts, gaskets, bypass hose, and thermostat.
All said and done, I saved myself $30 or so and supported a fellow forum member.
Thanks i will today , after i will do that test to see if the Plenum leaks , but i will change it anyway,as it is good improvement for the truck , more power and get more gas per mile,so yes i think it is a must.
Thank you for that info!
Regards.
Regards.
Hmm, Did the test and here is the video:
Did this , as curios about it ...
It was at "0" in the middle and then i start the truck up and it started to go up little by little
to the right .
Truck was warmed up and normal running temperature,and the test was done at idle.
I did let it run for about 30-45 sec. during the test.
to the right .
