My ram truck
130 bucks for a water pump? Just go with stock replacement, they last 100K plus miles, flow more than enough for typical usage. Save the bucks and spend them on something useful. (take your wife/girlfriend out for dinner.
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUDP Mini Overhead Console
CUVP Behind Seat Modular Storage System
CUYP Storage Tray
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
K17P Bodyside Molding
LAAP Ignition Time Delay Lamp
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHMP Speed Control
PRFA Metallic Red Clear Coat
QRFS Radiant Red Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TYWP P245/75R16 RBL RTS Tires
TZAP Goodyear Brand Tires
WLBP Steel Spare Wheel
WNDP 16X7.0 Cast Aluminum Wheels
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
YAAS Build To U.S. Mkt. Specifications
ADAP Light Group
APAS Monotone Paint
CUYP Storage Tray
EAAC All Engines
JJAS Cigar Lighter
JPAP Power Windows
JPBP Power Locks
LBCP Glove Box Lamp
LDAP Underhood Lamp
LPEP Cargo Lamp
MFDS Bright Grille
MXBS Front Air Dam
NHMP Speed Control
RCDP 4 Speakers
XBSS Pickup Box
So is a 9.25 rear good or bad? And I'm pretty sure the front said Dana when I was underneath. I eventually am going to 4.10 gears. Anyone do the tcc switch for manual torque converter lock? I was thinking about doing that and was curious about it
Do the seals when you do the gears. Otherwise, it's a lot of repeated work. (yes, stupid design.)
If you haven't done gears before, I HIGHLY recommend you find someone to help you that has, or, just pay someone else to do it. (yeah, I know, expensive.....) That is a job you do NOT want to mess up. Then it gets even MORE expensive.......
Might also consider looking for a set of axles from an Off-Road Edition truck. They came with 4:10s.
(axle swap is actually easier than a gear swap.....)
I would be extremely lucky if that happened. That's to easy. I have a brother in law who does mechanics and works at a place called 4 wheel parts now. I can have him help me one day
