how to bypass trans relay
Old Sep 25, 2015 | 09:57 AM
jrp79's Avatar
jrp79
Default how to bypass trans relay
how do I bypass the trans relay circuit on the 46re so the solenoid pack is always gettin power
Old Sep 25, 2015 | 10:09 AM
Is the PCM not controlling the relay? Is the relay bad? Are the fuses in the circuits good?
Which circuits are you having issues with?
Old Sep 25, 2015 | 10:20 AM
jrp79's Avatar
jrp79
I replaced the governor solenoid with a borg and changed the pressure sensor with a used tested one and trans still goes to limp mode.new relay and fuses are good.polarity is good from pcm to relay and getting power at pin 1 and 2 at trans connector with ign on and in drive.I just want to rule out the pcm before I go any further
Old Sep 25, 2015 | 10:22 AM
jrp79's Avatar
jrp79
also the relay clicks when truck starts but clicks again after bout 4 or 5 sec and thats when the light comes back on
Old Sep 25, 2015 | 11:14 AM
Getting any trans codes?
Old Sep 25, 2015 | 11:19 AM
jrp79's Avatar
jrp79
p1762 p0753
Old Sep 25, 2015 | 11:27 AM
P0753 Trans 3-4 Shift Sol/Trans Relay Circs
P1762 Gov Press Sens Offset Volts Too Low or Hi
Got a scanner that can read data? Need to see what pressure sensor thinks is going on.
Old Sep 25, 2015 | 11:31 AM
jrp79's Avatar
jrp79
the one I have reads freeze frame.not sure if thats the data.never understood what that was
Old Sep 25, 2015 | 11:33 AM
If it can do freeze frame, it should be able to show raw data as well. But, even just a shot of what's going on won't hurt. Find governor pressure voltage, see what it says. Take it from there.
Old Sep 25, 2015 | 11:36 AM
jrp79's Avatar
jrp79
when I checked for volts at the vehicle side trans harness the volts didn't match what was supposed to be there.
at pin 4 to chassis ground was .23 and pin 5 was .14 in drive
pin 1 .03 and pin 2 .04
