idle loops
Old Jun 30, 2018 | 11:52 AM
  #61
Eman2004's Avatar
Eman2004
Default Anything special about markings?
I take it you guys use a threaded puller usually, but anything special about the markings? I have it set to TDC on the compression stroke.
Old Jun 30, 2018 | 04:04 PM
  #62
Eman2004's Avatar
Eman2004
The chain looks sagging, but the marks are in time. This sucks
Old Jun 30, 2018 | 04:54 PM
  #63
Since you are there, I would replace the chain anyway, then take it and have fuel sync set. Move the distributor to align the marks a bit better, while everything else is set. See if it runs any better.
Old Jun 30, 2018 | 05:48 PM
  #64
2bit's Avatar
2bit
Yeah, that chain is really loose. The other possibility is the outer ring on the balancer moved.
Old Jul 1, 2018 | 07:59 AM
  #65
Eman2004's Avatar
Eman2004
Default Possibilities
I’m wondering if I bumped the distributor when I was doing the rotor and cap? However, I can’t turn it by hand currently, so it needs to be loosen. So, I’m wondering if the we rotor is off from the manufacture or plant? It’s from Autozone, but I also bought one from track Auto, so it seems unlikely that both are bad from the factory.
Old Jul 1, 2018 | 08:03 AM
  #66
Check and see if number 1 is actually AT top dead center......
Old Jul 1, 2018 | 01:03 PM
  #67
Shadow_Death's Avatar
Shadow_Death
While you have it all off consider replacing the water pump if it's the original.
Old Jul 1, 2018 | 01:05 PM
  #68
Eman2004's Avatar
Eman2004
i already bought one 😉
Old Jul 1, 2018 | 01:53 PM
  #69
racefan41's Avatar
racefan41
Its a good idea to put a new fan clutch on the new water pump too.
Old Jul 1, 2018 | 04:20 PM
  #70
Eman2004's Avatar
Eman2004
That is a good idea, so can you send me money? J/k I’ve already dumped too much already, so now I’m trying to save as much as possible. Thanks for the recommendations though 😉
