2nd gen Cali coded ECU question
I have a '95 that needs a new ECU. I have learned that the stock ECU is the cali coded one, serial number 56028473. The ONLY one I can find out there is 56028475. One number off!
Does anyone out there know if that will work? The one I can find says it's cali coded as well, but just that one number off! I don't want to plug it in and risk blowing something up.
Also, I've been told that since it's a '95, not a '96, that this particular ECU can't be re-flashed and rebuilt. I just have to find a replacement.
Thanks in advance for any help!
What type of engine do you have?
what type of truck?
that will help us help you to figure it out
in 1995 the only dodge v8 engine to have more than one o2 sensor is the ram 3500 one ton dully with 360 v8 and dual exhaust. With heavy duty emissions. It had left and right bank o2 sensors dual cats and air injection to the cats
all other v8s had one o2 sensor and single exhaust
if if you run a single o2 comp on a dual o2 engine.......it will run, not well at idle, but will run off of just the left bank o2 signal
the 60 way connector has the same wireing for all v8s they just leave a couple of holes where wires would go for 2nd o2 and trans temp signal.
what type of truck?
Oh yea and a company called sia electronics can possibly repair it
they tried with mine, charged me 95 bucks and it didn’t work, shipped it back to them and for some reason there test bench found no problem, I actualy found two more comps on eBay with same part number and they work fine
sia electronics sent my comp back and refunded me all my money, the tech was a great guy and apologized that he couldn’t find a problem
had great conversations with them and I would definitely send one of my other comps to the to get repaired
viperdave
viperdave
Great info! Thank you!
It's a 4x4 auto trans, 5.9 gas Magnum.
I've ran the vin (3B7HF13Z0SM160123) at a dealer and they told me it's a Cali emissions truck (and I did inherit the truck from my grandfather in Oregon).
And yes, it has just the one o2 sensor.
It's a long story, but this truck has ran perfect up till I took it to a shop and had them replace the headers. They tried putting on cheap ones that did not have the ERG port, so they blocked off the ERG. That's when the sh!* hit the fan and they couldn't figure out why it ran so rough. They eventually fried the mother board of the ECU jacking with it. They finally got headers with the ERG port and I tracked down an ECU on ebay with the same serial number (56028473). Got it all back together, been running fine for a while and now all of a sudden it's in the same boat as before. Acting the same way as when the last ECU got fried.
Trending Topics
Haven't tried this time. The last time it did this, when hooked up to the diagnostic it couldn't read anything because it was so jacked.
There's no check engine light or anything. It idles rough, stutters at cruising speed and if in overdrive it'll stutter so bad it's hard to keep it on the road.
