46re trans issues?
Old Feb 13, 2020 | 07:03 PM
  #31
I would be more interested in what he does when he puts it back together.......
Old Feb 13, 2020 | 07:23 PM
  #32
Sheldon Fuller's Avatar
Sheldon Fuller
ok so the video also on the reassembly doesn’t show him tightening it he just says to make sure it’s between the plunger and the head of the adjustment screw
Old Feb 13, 2020 | 08:10 PM
  #33
Sheldon Fuller
ok with the valve body out I also noticed something cracked that may be from reassembly. The grey plastic peice is cracked on the lever
Old Feb 13, 2020 | 08:11 PM
  #34
Does it alter the way it moves?
Old Feb 13, 2020 | 08:25 PM
  #35
Sheldon Fuller
no I don’t believe so
Old Feb 14, 2020 | 08:25 AM
  #36
may or may not be an issue then. If you have one in better shape, install that one.
Old Feb 14, 2020 | 11:24 AM
  #37
Sheldon Fuller
I don’t have another one :/ would that cause my downshifting problem? That seems to be my only problem now
Old Feb 14, 2020 | 11:47 AM
  #38
Normally, the TV cable controls downshifts. But, if that all seems to be working properly........ I don't know......
Old Feb 14, 2020 | 11:56 AM
  #39
Sheldon Fuller
well I just thought it maybe was something else. Just do to the simple fact of, when I come to a stop now the truck WILL stall. And the throttle isn’t pulled when you stop. So I’m not exactly sure wth is going on.
Old Feb 14, 2020 | 12:05 PM
  #40
Sheldon Fuller
mom honestly half tempted to tighten that adjustment screw on the valve body until it’s touching and see what happenss
