Help with misfire and bogging down
Old Sep 23, 2020 | 07:36 PM
  #91
Goshdarnram's Avatar
Goshdarnram
thank you very much for all your help!
Old Sep 23, 2020 | 07:59 PM
  #92
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Goshdarnram
I’d like to try and do it as cheap as possible but as good as possible I want to keep the truck I’ll check the ball joints tomorrow is there a way maybe one ball joint went bad and it causing hard turning on one side?
Cheap and good don't go together for a steering box lol. As HeyYou said Redhead or the other one are about the only good ones. It's very possible but if one is bad replace both on that side as you are already there.
You are welcome
Old Sep 23, 2020 | 08:01 PM
  #93
Goshdarnram
I know lol but I can try xD but I’ll let you both all know how it goes tomorrow I’m going to jack it up and pull on the tire any thing else I should check since I’m there?
Old Sep 23, 2020 | 08:04 PM
  #94
MoparFanatic21
Grabbing at 3 and 9 will check the tie rods for play. Also spin the tire and see if you hear any noise (faster you can spin it the better) that will sometimes tell you if your universal joint is bad or if the first shield is rubbing the rotor
Old Sep 23, 2020 | 08:07 PM
  #95
Goshdarnram
Alright I will definitely how do I know if there bad?
(the ball joint / tie rod)
Old Sep 23, 2020 | 08:37 PM
  #96
MoparFanatic21
The wheel will move and then (this is the hard part) you will have to move it but look behind the wheel to see where it's moving. That will tell you what is bad. The 12 and 3 will also check the wheel bearing. You can find YouTube videos on the exact procedure if you are a visional learner
Old Sep 23, 2020 | 08:39 PM
  #97
Goshdarnram
Aright that sounds good to me will let you know what I discover
Old Sep 23, 2020 | 08:43 PM
  #98
MoparFanatic21
I will keep checking
Old Sep 23, 2020 | 08:47 PM
  #99
Goshdarnram
Thank you very much!
Old Sep 24, 2020 | 07:26 AM
  #100
The box does look like its relatively recent. Lotta fluid around there though, what's leaking?
If it works one way, but, not the other, that's an internal valve problem on the steering box, and it needs to be replaced.
