Help with misfire and bogging down
Old Nov 19, 2020 | 09:27 PM
  #191
Gently. I used a garden hose on my 96 truck. I *really* need to do it on my current truck as well, as the heat just sucks....... I think it is even mislabeling it calling it 'heat'.... More like, '**** warm'....... if it gets that hot. And on the sub-zero days we occasionally get, that REALLY sucks. Supposed to be nice out tomorrow. Maybe I will poke at it.
Old Nov 19, 2020 | 09:29 PM
  #192
Goshdarnram's Avatar
Goshdarnram
I think they make a tool I might look at to back flush it hmmm got ideas poking around now myns the same way it’s better then outside about 20-30 but not by much lol
Old Nov 19, 2020 | 09:33 PM
  #193
And only if you DON'T put it on High speed fan. If I do, I might just as well roll down the window. Its about the same effect.
Old Nov 19, 2020 | 09:35 PM
  #194
Goshdarnram
Same here lol it’s bad my friend has a 97 dodge 1500 5.9 in it heater cores leaking in the floor but heat works perfect lol do you know if there’s a difference in 4wd or 2wd steering gear boxes?
Old Nov 19, 2020 | 10:56 PM
  #195
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Mine is the same I think I either have air in the system, need to back flush the core, or the 180 stat is to cold
Old Nov 19, 2020 | 10:58 PM
  #196
Goshdarnram
Yeah if back flushing myn doesn’t work I’ll try changing the thermostat on it
Old Nov 19, 2020 | 10:59 PM
  #197
MoparFanatic21
They might work but only if it's stuck open
Old Nov 19, 2020 | 11:26 PM
  #198
Goshdarnram
What’s weired is both my heater hoses are hot so it doesn’t seem clogged but idk
Old Nov 20, 2020 | 09:06 AM
  #199
If there is an air pocket, heat transfer will be really inefficient. Which I suspect is what we are experiencing. I already changed my thermostat, and the engine does indeed get up to temp, but, the heater isn't nearly as effective as I would like. On a long trip, it will eventually start blowing really hot air, but, if it sits and cools, it's another good distance before it starts working the way I think it should. I believe the heater core is the highest point in the cooling system though, and that makes it kinda difficult to get all the air out.....
Old Nov 20, 2020 | 11:34 AM
  #200
MoparFanatic21
See I tried to fill the heater core but didn't have spare hose to make it long enough. My problem is it blows warm when sitting and warmer when moving but never hot. I thought it might have been the 180° stat. My gauge get a little about the 130 mark
