Help with misfire and bogging down
Old Sep 21, 2020 | 02:58 PM
  #71
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This one is the 15:1 ratio, makes for more responsive steering, the 18:1 box is used on the heavier duty trucks apparently.
Yep and the thing is if you send them the wrong ratio you forfeit your core charge
Old Sep 21, 2020 | 04:16 PM
  #72
Goshdarnram's Avatar
Goshdarnram
Oh dang is there any way to tell what my current one is?
Old Sep 21, 2020 | 10:32 PM
  #73
MoparFanatic21
On their website they have a way to tell you count how many turns it takes to go from lock to lock. Look on their website
Old Sep 21, 2020 | 10:35 PM
  #74
Goshdarnram
Will do thank you
Old Sep 23, 2020 | 02:33 PM
  #75
Goshdarnram
Fixed 4wd it was that switch now light comes on and everything
Old Sep 23, 2020 | 04:56 PM
  #76
Awesome.
Old Sep 23, 2020 | 04:57 PM
  #77
Goshdarnram
Thank y’all very much! Will keep updated with the steering
Old Sep 23, 2020 | 06:47 PM
  #78
Goshdarnram
Okay so I jacked the front end up on the truck it turns just like it should turns perfect but on the ground it’s supper hard any ideas?
Old Sep 23, 2020 | 06:49 PM
  #79
When its jacked up, yep, it's gonna turn easy.
Crank it from lock to lock a few times, engine running, have a look at the fluid, see if there are any air bubbles in there.
Old Sep 23, 2020 | 06:52 PM
  #80
Goshdarnram
If the valve was bad in the gearbox wouldn’t it make it hard to turn that way anyways? Idk I’m just asking
