R46h Rebuild
#121
#122
Get rid of the platinum plugs. Standard copper are the way to go. The rare earth fellers can give you mystery misfires.
#123
With a wide variety of options there is to choose from, I'm sure, for a warm engine miss, such a sensor issues I think I might as well go ahead and just order all the sensors and change them out too. Because it seems like that the shake is worse as the engine warms up. For instance going to town when it shifts into overdrive at 50 mph, it's not as violent a shake versus coming back with a warm motor, and it shifting into overdrive at 50 mph. So I'm looking for input on that.
#124
#127
#128
Okay... TY... Taking it back to the transmission man tomorrow. I don't see how it could be a miss anywhere in the motor, when it's getting worse. Used to be if it shifted into overdrive when I was going between 40 and 50 it would shake now if it shifts into overdrive even between 50 and 60 it shakes and I mean it shakes bad enough to where you can't drive it while it's shaking it's going to shake something up but thank you so much my brother.
#129
#130
Well like I say I just got through giving it a whole complete tune-up with excellent parts and it otters pretty decent and when you step on it it'll get somewhere in a hurry... If I wasn't a ball guy I would pull my hair out over it by now... As I said before the moment it starts shaking you give it a little throttle and the minute it kicks down into the next gear it's shaking stops but when it goes back into overdrive and start shaking again. I know the firing order is right because I did everything very meticulously and double check it after I was done... Like I say it starts really well.. and gets on it real good but I will even admit it still sounds or feels like a myth when it's idling I don't know where to go from here. You said don't fire the parts cannon at it but without a diagnostic tool and my obds aren't showing anything I'm kind of stymied. I don't want to shake up that new transmission.
