R46h Rebuild
R46h Rebuild
I have a 1994 Ram 1500 Laramie SLT. 2 wheel drive, 318v8, 192,000 miles. Bought it really cheap with Transmission trouble. Will not up shift without letting off gas pedal, then only to 2nd. I changed the fluid (from pan) did not flush system. Installed new Shift Solinoid, filter, had some shavings and small pieces of aluminum from (?). Researched ID#, came back R46H. No repair history. I pulled the tranny. QUESTION IS..how difficult is that model to rebuild. I've heard DON'T TRY IT, to easy as any.
Welcome to DF!
Actually, several members here have rebuilt their own transmissions, having never be inside an automatic before. There are LOTS of resources available on the web for how to go about it, there is even a youtube series on it.
Oh, and it's 46RH. (4 speed, 6 is "relative torque capacity" whatever that means..... R is rear drive, H is hydraulic control) TCC and O/D are controlled by the PCM, via the solenoids. Get yourself a GOOD rebuild kit, and torque converter, take your time, and you can do this. Only real tricky part is that 800 lb/in spring in the o/d housing...... Need a press and the right tool for that. (watch the videos. )
I bought a Chilton manual on the truck but I'm going to order a rebuild manual on that particular transmission also. I have all the tools and have some skill.. nice clean place to work so I will order the manual for that tranny, but I would like to know where is the best place to buy a complete overhaul kit for that transmission...
You can download the factory service manual for your truck from here. I thought we had the trans manuals around here somewhere as well, but, I can't come up with 'em at the moment. (no idea if they are any better/worse than the service manual....)
Check out these guys for rebuild kits, and converters.
Do you happen to have a picture of the Aluminum that was in the pan? I changed the fluid in my trans a little while back for the second time since I have owned the truck. And had some in the bottom of my pan. But the trans seems to be shifting fine.
I’m interested to see where you find that it all came from.
I have it out in the shop in a paint strainer all I have to do is find that paint strainer I can tell you now though it looked like a piston ring that had been broken into several pieces a half inch to maybe 1 in Long.. but it was aluminum, about five pieces.. I can send a photo of the transmission filter as well which has quite a bit of small shavings on it nothing large. The only history I got out of the seller was that the truck began to have shifting problems and then one morning it wouldn't shift at all..
Trending Topics
Yessir, I plan on repairing or replacing EVERYTHING I can. I have rebuilt and beefed up some GM turbo valve bodies in my youth but NEVER an entire rebuild. In the Dallas Texas area the cost of a a SHOP REMOVE, REBUILD (?}, AN REPLACE IS 1600 TO 1800.. (I hope I'm allowed to say that), I'm retired military so I got the time. I'm a little intimidated but I think I can do it ESPECIALLY with technology. AND THIS FORUM. I'm ordering a manual. I'm posting a pic of it to get some input. But, THANK YOU, for input, that very likely where that "ring" looking shrapnel came from
I'm not representing or endorsing this product or any affiliate.
