AC Oil
Old Mar 25, 2021 | 04:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default AC Oil
How much oil does the AC system take and where do you put it in at? I just replaced all the lines on my 2001 Ram 2500 and I have a buddy who will pull a vacuum and charge it for free I just have to add oil.
Old Mar 25, 2021 | 07:54 PM
Should be in the service manual.... I think it even tells ya where to put it..... (hhmmm.... that just doesn't sound right....... )
Old Mar 25, 2021 | 08:47 PM
MoparFanatic21
It says 6.25 but not where to put it lol I know there is still some in it but I'm going to try and charge it and see what happens lol
Old Mar 25, 2021 | 09:57 PM
MoparFanatic21
Well charged it had AC for three seconds turns out the condenser is leaking lol
Old Mar 26, 2021 | 06:53 AM
From what I have seen, folks put a bit in the compressor, some in the accumulator, and even some in the condenser....... Don't wanna put it all in the compressor, as you don't want to hydro-lock it, and destroy it.
Old Mar 26, 2021 | 07:01 AM
Moparite's Avatar
Moparite
Put it in the receiver/dryer.
Old Mar 26, 2021 | 10:13 AM
MoparFanatic21
When I install the new (used) condenser I will add some oil to it. This is just a trial run. If the compressor blows it blows and I'll have the system evacuated, vacuum pulled, and recharged with the right amount of oil and freon. To do all that a garage wants $350 and that's the cheapest I found.
Old Mar 26, 2021 | 11:28 AM
ol' grouch's Avatar
ol' grouch
I don't like to reuse old receiver/dryers from a junk yard. I'll reuse one when I open then pump down a system right away. The dryer can only hold about a tablespoon of moisture. I put most of the PAG oil in the compressor, a little in the condenser and dribble a little into the lines.
Old Mar 26, 2021 | 05:02 PM
MoparFanatic21
I replaced all the lines and dryer yesterday (new from Rockauto) so they is what is driving me to get the AC working lol
Old Mar 26, 2021 | 07:24 PM
ol' grouch's Avatar
ol' grouch
If you're like me (and I know I am) I'd want to get it working and not worry about it. When I fixed my Escalade a couple of years ago, I went ahead and replaced the compressor too. That way you don't have an old one fail and dump a bunch of metal junk in the system you have to clean out. I'd even go so far as to replace the serpentine belt if it's got much age on it.
