Nv3500 clutch
Old 03-28-2022, 02:21 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Originally Posted by ThatRedRam
Im doing more then a carb swap just starting there. Im looking for 600 horsepower and ill be dropping the clutch a good bit ngl i already do. Hopefully stock clutch will hold and hopefully the trans will too. Worst case ill nv4500 swap the truck.
At 600hp the stock clutch is still good. Unless you are dumping $25,000 and getting closer to 800 the stock clutch will most likely hold. Not the NV3500 will not I THINK it's only rated for 300hp and 380tq.
Old 03-28-2022, 08:20 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
Just buy a twin disc clutch….it’s not considered stage 1 or 2, but the twin disc clutch will hold power and be all you need. We’ve ordered quite a few at shop for Cummins (nv4500) I don’t see how your having issue finding one?
Old 03-29-2022, 08:54 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
600 HP will smoke an NV3500 the first time you dump the clutch. I wouldn't expect even the NV4500 to survive long with that kind of treatment.
Old 03-29-2022, 11:04 AM
MoparFanatic21
I think the 4500 would if you didn't beat on it. I would either build the 4500 or G56 swap it
Quick Reply: Nv3500 clutch
