Crank no start
Old 11-12-2022, 03:55 PM
B0dh1M0d3's Avatar
B0dh1M0d3
B0dh1M0d3 is offline
Hooked up obd code reader and seems to be none showing up
Old 11-12-2022, 05:15 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Does the scanner show stored and pending codes?
Old 11-12-2022, 06:19 PM
B0dh1M0d3's Avatar
B0dh1M0d3
It is capable of doing so but showing none on there.. which I feel like there should be something
Old 11-12-2022, 08:18 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
The computer is kinda stupid.... and for some sensors, it really doesn't know if what it is getting is correct, so, it just 'assumes'.....
You get the initial fuel pump prime, but, does the pump run for a few seconds after cranking as well?
Old 11-14-2022, 12:19 PM
B0dh1M0d3's Avatar
B0dh1M0d3
No I dont believe I hear the fuel pump still after cranking
Old 11-14-2022, 12:22 PM
B0dh1M0d3's Avatar
B0dh1M0d3
would the computer lose codes if my battery wasn't connected for a couple weeks?
Old 11-14-2022, 12:28 PM
HeyYou is offline
Sounds like a bad crank sensor.
And yep, disconnect the battery, PCM forgets everything it knew about running your engine. Including codes.
Old 11-14-2022, 01:02 PM
AtomicDog's Avatar
AtomicDog
You can also fully charge up the battery, re-connect it to the truck and try starting it again. It should generate a code that the code reader should display to help you to further pinpoint your issue.
Old 11-14-2022, 01:54 PM
B0dh1M0d3's Avatar
B0dh1M0d3
Do all obd code reader have that capability, I was using Zurich 8s I believe. I tried cranking with obd hooked up but didn't give me any codes
Old 11-14-2022, 02:29 PM
HeyYou is offline
Not every fault will set a code. That's what keeps troubleshooting interesting.
See if you have spark while cranking.
Quick Reply: Crank no start
