Crank no start
Old 11-10-2022, 09:58 AM
B0dh1M0d3's Avatar
B0dh1M0d3
B0dh1M0d3 is offline
Default Crank no start
I have 2001 dodge ram 1500 5.9... having a crank no start issue .. my fuel pump is good but curious to know if while cranking the motor is it normal for the check engine light to be on ?? If not does anyone know what that may mean ... I never noticed it before I know but I also never paid attention... Also have noticed the truck seems to sound a little different like a winding noise when it's cranking but also never paid attention before cause it had always started
Old 11-10-2022, 10:48 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Have you hooked up an OBD2 scanner to check for any stored or pending trouble codes? If not, the codes should help to identify the issue. When I experienced that issue a while ago, it was a bad crank sensor and the code I pulled pointed to that being the issue.
Old 11-10-2022, 09:31 PM
B0dh1M0d3's Avatar
B0dh1M0d3
I don't have a scanner at the moment ... But will definitely try that as soon as possible
Old 11-11-2022, 06:27 AM
Moparite's Avatar
Moparite
Moparite is offline
Yes, after the engine starts and there are no codes then it will go out. If you have any it will stay on.
Old 11-11-2022, 11:32 AM
B0dh1M0d3's Avatar
B0dh1M0d3
I'm only getting 1.6 volts to my injectors, is that low and if so what would be cause
Old 11-11-2022, 11:49 AM
AtomicDog's Avatar
AtomicDog
Post
They are available at WalMart.com for about $20 or less. Obtaining the code(s) tends to alleviate any guessing as to what the problem is..
Old 11-11-2022, 02:17 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,273 Likes on 3,020 Posts
You will only see voltage at the injectors for about 3 seconds after initial key on, and then if the PCM sees the engine turning. That said, injectors want 12 volts.
Old 11-11-2022, 02:23 PM
B0dh1M0d3's Avatar
B0dh1M0d3
As I'm cranki g only getting 1.6, then does that mean pcm is not worki g
Old 11-11-2022, 02:25 PM
HeyYou is offline
Does the fuel pump run while cranking?
Old 11-12-2022, 10:16 AM
Moparite's Avatar
Moparite
Moparite is offline
The asd relay supplies positive power(battery +) to the coil,02 sensors and the injectors. You should have power there while cranking, If not the asd relay might be bad or not coming on.
Quick Reply: Crank no start
