Transmission rebuild is obvious answer
Old Apr 19, 2023 | 03:00 AM
  #141
Sirriggs's Avatar
Sirriggs
Keeping head down and making progress here so far. I have it done the the pump installed. Did a bench air check and everything worked as intended. Can't find feller gauge so going to make a stop by the auto store to pick one up on the way home so I can do check, then on to getting the band done and adjusted, Then go from there.I can say I am learning a lot from this. I am going to post a couple of pictures and will continue to update. Thanks
Old Apr 20, 2023 | 01:40 AM
  #142
Sirriggs's Avatar
Sirriggs
Well officially down to the valve body. I will admit though I had to go back in and flip the band. lol, Brain fart I would call after putting in upside down. I still thinking about get another torque wrench that goes up to 100 Num. I didn't realize the one I bought doesn't go up enough to go by the 72 lbs Num to may a proper adjustment. I'm pretty confident I did a pretty good job so far. Few hiccups but I am sure that is expected with a first time rebuild. I figure once this is done. I will be looking at a new timing chain since it hasn't been done with the millage it has. Thanks Guys.
Old Apr 20, 2023 | 09:43 AM
  #143
If you are talking band adjustment, they get torqued to 72 INCH pounds.....
Old Apr 20, 2023 | 12:18 PM
  #144
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I'm curious what the number on the apply band lever is. Mine was 2.5 but now has a 4.2 from perf kit.
Old Apr 20, 2023 | 01:14 PM
  #145
AtomicDog's Avatar
AtomicDog
Post
I've got a 4.2 in my transmission as well during the last rebuild.
Old Apr 20, 2023 | 06:10 PM
  #146
Sirriggs's Avatar
Sirriggs
I bought a num torque but didn't realize it only goes up to 40. Just have to break down and buy another one but one that reads high enough. I have the info just not the right torque wrench. I still have a few things to finish as well some more parts to get so not rushing here. Have a O2 sensor to replace as well as new lines. Other than a few hiccups. It wasn't bad at all.
Old Apr 20, 2023 | 06:15 PM
  #147
Sirriggs's Avatar
Sirriggs
I couldn't answer that? Would it be visible? I just know it was a deluxe kit.
Old Apr 20, 2023 | 07:25 PM
  #148
That would be it's ratio. The 2.5 is stock, the 4.2 is an 'upgrade' and applies more pressure on the band.
Old Apr 20, 2023 | 09:38 PM
  #149
Sirriggs's Avatar
Sirriggs
Ok, Thanks for answering that. It's still pretty much stock here.
Old Apr 21, 2023 | 12:04 PM
  #150
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Yea, the ratio not the part number. Brain farts at times.
