Alarm/remote starter
Old Jul 20, 2011 | 12:33 PM
  #41
dingdong2's Avatar
dingdong2
Originally Posted by Six_Shooter
You need it, all 2006+ Dakotas have the IMO.
It seems that 2005 it was an option.
Sure way to know: Grey key = IMO, and a keyless key (that sounds wrong lol) = IMO.
My key is black and I don't have keyless entry (I don't even have power locks). I know there's no chip in my key because I can peel the rubber off of the metal key and I have made copies of the key before. What kind of IMO is it? Is it like GM's passkey, where there's no chip in the key because it is activated by resisters in the lock cylinder (or something like that)?
What does IMO mean? Immobilizer?
Here's a pic of my OEM key
Old Jul 20, 2011 | 06:59 PM
  #42
Six_Shooter's Avatar
Six_Shooter
Interesting.
The information I have found says that 2006+ all had the IMO, but it appears yours doesn't.
Old Jul 21, 2011 | 12:51 AM
  #43
dingdong2's Avatar
dingdong2
Interesting.
That's why I didn't buy the bypass module yet. I know there's no chip in the key but the vehicle specific wiring guide on Bulldog Security's website says that there is an Immobilizer (see link below). It says that it has "CHRYSLER'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM." Anybody know anything about that, like how it works? Is it like GM's passlock2 where it detects the lock cylinders position?
http://www.bulldogsecurity.com/diagr...9997&MakeID=16
http://documents.audiovox.com/700654.pdf
Old Jul 21, 2011 | 01:06 AM
  #44
Six_Shooter
It's a transponder, which it seems you don't have.
Old Jul 21, 2011 | 05:05 PM
  #45
jose13b's Avatar
jose13b
if you need help looking for these wires let me know and if you dont have door locks then thats less to hook up
2006-2007 dakota
12 VOLT CONSTANT RED (x2) and RED/LIGHT BLUE (+) @ IGNITION HARNESS
STARTER PINK/LIGHT BLUE (+) @ IGNITION HARNESS
IGNITION 1 PINK/LIGHT GREEN @ IGNITION HARNESS
IGNITION 2 PINK (+)
IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 PURPLE (-) and PINK/WHITE (+) See NOTE *1 @ IGNITION HARNESS, See DIAGRAM
ACCESSORY/HEATER BLOWER 2 PINK/YELLOW (+) (X2) @ IGNITION HARNESS
PARKING LIGHTS ( - ) PINK/RED (-) @ HEADLIGHT Switch or cluster, GRAY 16-Pin Plug, Pin 5
PARKING LIGHTS ( + ) PINK/RED (+) and WHITE/ORANGE (+) USE BOTH! See DIAGRAM @ IMP, 20-Pin Plug, Pins 15 and 17 See NOTE
*2 POWER LOCK PURPLE/DARK GREEN 1-Wire System, See NOTE *3 in DRIVERS KICK PANEL or Cluster GRAY 16-Pin Plug, Pin 3 POWER UNLOCK Same wire See NOTE *3 Same wire
DOOR TRIGGER See NOTE *4 in Each Kick Panel See Diagram DOMELIGHT SUPERVISION YELLOW/ORANGE (+) @ Cluster, WHITE Plug,
HORN DARK GREEN/PURPLE (-) @ HORN Switch
TACH Any wire not RED @ Any Ignition Coil or Fuel-Injector
BRAKE WHITE/LIGHT BLUE (+) @ Switch Above Brake Pedal
FACTORY ALARM DISARM Disarms with Factory Remote Only ANTI-THEFT CHRYSLERS SENTRY TRANSPONDER, See NOTE *5 @ IGNITION SWITCH TUMBLER EXTRA INFORMATION NOTE *1 the PURPLE (-) Accessory wire must be powered up using an extra Relay Part R30-H, See DIAGRAM NOTE *2 the IMP (Interrated Power Module) is located at the FUSE/RELAY Box on the Drivers Side Fender. NOTE *3 the 1 Wire door locks on this vehicle will require a 330 Ohm Resistor to LOCK and a 100 Ohm Resistor to UNLOCK See DIAGRAM NOTE *4 DRIVERS Front door is a PURPLE (-) in the GRAY 26-Pin Plug Pin 6. The PASSANGER Front Door is a PURPLE/WHITE (-) in a WHITE plugPin 23. The DRIVERS REAR Door is a PURPLE/GRAY (-) in a GRAY 26-Pin Plug, Pin 8 and the PASSANGER REAR Door is a PERPLE/YELLOW (-) in a WHITE Plug, Pin 22. When connecting to an Alarm system use all 4 wires and DIODE ISOLATE, See DIAGRAM NOTE *5 The CHEYSLER'S SENTRY TRANSPONDER ANTI-THEFT System is STANDARD on the SLT Package and LARAMIE Models.
Old Jul 21, 2011 | 05:34 PM
  #46
jose13b's Avatar
jose13b
vipor is hard to program , you have install that alarm (made by DEI) in order to know what you are doing I install alarms and remoter starters by autopage and there tech support will always help you.DEI tech support wont talk to you if you are not a dealer with them. all alarms do the same thing vipor is just a name that has been around for a long time
Old Jul 21, 2011 | 05:50 PM
  #47
jose13b's Avatar
jose13b
and yes black no chip only gray keys thats for all dodge and Chrysler and jeep
Old Jul 21, 2011 | 09:33 PM
  #48
Six_Shooter
Viper systems aren't difficult to program. They are some of the easiest, even without the hand held programmer.
Old Jul 22, 2011 | 09:49 PM
  #49
dingdong2's Avatar
dingdong2
So I shouldn't need the bypass module then? Thanks for the help. I might need assistance along the way but I wont know till I start ripping **** apart.
Old Jul 22, 2011 | 10:26 PM
  #50
In My Opinion....sometimes....in this thread? idk
