Superchips Questions and Updates
#1103
They are really working hard on them Jason. It's an extremely complicated program. Engineer has to give the go ahead. Hopefully we'll be going to some beta testers soon.
Sil
Sil
#1104
New firmware/database we're working. A couple of new menus.
To continue in TM now, you'll have to choose a Trq table.
User/Superchips/Stock. This makes things a little more user friendly for the end user.
Here's what some of the new %'s will look like. The numbers you see are actual stock values. They no longer will start at 100%, but they are stock.
Lower is less TM. This setup is helping us address the rounding errors we're experiencing. Just an FYI: Superchips won't release any values they use.
Want 0% ZERO TM? You got it.
We're still experiencing some numerical rounding issues with TM.
I can't be sure what you see here will be the exact final product, but it's very close and gives you an idea. They still could make changes.
Simply put, it's an incredible program and only Superchips could make it happen.
Sil
Sil
#1106
I haven't Nick. I do take it for test runs, but I'm more so beating on the program itself when plugged into the truck. Running through menus. Save/Exit and Reset routines, etc. This evening I found a bug they'll need to address. The program is almost there. We're working it very diligently.
Sil
Sil
#1107
I know this is a stupid question, but do you keep the programmer plugged in the whole time or just when you're loading the new tune? Where exactly do you keep it if you do? I know the EdgeEvolution tuner comes in a nifty display pod that mounts on your dash so you can see all of your readouts. Thanks.
#1109
The newer generation Flashpaq and Cortex are small enough to fit in a universal cell phone holder. When not in use, I would personally keep the tuner out of a hot vehicle.
Very good questions.
Sil
#1110
After you complete your tuning, you can keep the programmer plugged in to data log.
Sil
Sil
