Diablo Information and Reviews
Old 12-16-2010, 07:42 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You can through the usage of the 2 channel analog input (2.5mm stereo cable) at the bottom of the unit and additional add-ons.
  #812
Old 12-16-2010, 02:11 PM
SILVER DAYTONA's Avatar
SILVER DAYTONA
SILVER DAYTONA is offline
Default Any tips to get the most out of it.
Originally Posted by Marx
got everything running smoothly. Any tips to get the most out of it?
Post up your last written tune on the Diablo forums and ask to have your throttle sensitivity inreased and the tourque management reduced and you will like the results.I just did and wow what a diffrence it made for driving around. I see you have an 05 and the performance trans option and the above mentioned things make a big difference.
  #813
Old 12-16-2010, 02:58 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
TM IDK about the the throttle sensitivity you can adjust on your own
  #814
Old 12-17-2010, 03:04 PM
SILVER DAYTONA
They can adjust it some more,believe me. Weedahoe give them your last written tune and try it out. You will like it. Feels like the old cable actuated throttle on older trucks and cars.
  #815
Old 12-17-2010, 06:43 PM
xtremekramer's Avatar
xtremekramer
xtremekramer is offline
Well.... I am back with the DSP! Switched to a SC for about 3 months. Transmision shifts were awesome with it... However I wasn't getting any milage benefits with it. Even when it was set for fuel saver and canned trans options. I was getting 2.5 -3 mpg with the DSP. I am planning to play with the dsp trans options this week. Does any one have a good starting point for an 08?
  #816
Old 12-18-2010, 12:05 AM
truckin151's Avatar
truckin151
truckin151 is offline
They can crank it up beyond your user settings. The tune Hemifever wrote for my cam has the throttle sensitivity cranked up well above what it is for user settings (however you can adjust it further with the user settings after the tune as it is based off of the starting tune). Pretty sure the diablo guys are doing it similar... however I would not let them touch your tune since its a custom tune file.
  #817
Old 12-18-2010, 09:59 PM
$Piker's Avatar
$Piker
$Piker is offline
[quote=weedahoe;2350867]That all. A USB cable is nice but they are less than $5 so its not a deal breaker if the seller doesnt have one
So the "PC Interface" isn't a required item to update the programmer? I read somewhere that I could get a normal USB cable from radio shack and it would work. True?
Thank you for the help.
  #818
Old 12-19-2010, 01:26 AM
SILVER DAYTONA
Thats what I use.
  #819
Old 12-19-2010, 12:56 PM
$Piker's Avatar
$Piker
$Piker is offline
Just ordered mine from truckcustomizers.com. $287 shipped.
  #820
Old 12-19-2010, 03:08 PM
truckin151's Avatar
truckin151
Just head down to radioshaq and pickup a USB cable and a power adapter and call it good, shouldnt cost more than about $20 if that.
Quick Reply: Diablo Information and Reviews
