Diablo Information and Reviews
#821
Will do. I cant wait to get it all set up. The way this thing shifts drives me crazy....
#823
and I have a few(probably dumb) questions. FYI-I have an 06 2WD 4.7L. I only have the 87 and 93 Diablo tune options, not the 91. Anyone know why? I put the 87 perf tune in, but didn't change any parameters. Should I change any? So far, I only have a CAI and flowmaster SI/DO exhaust. I would use the 93 tune but most stations near here only have 92. Thanks.
#824
The only changes I would make are speed limiter and shift points. You will need to play with the shift points to meet your needs. Look in the Diablo sticky for more info.
#825
I have a 03 dodge ram 5.7 Hemi, i need to get a programmer and I`m not sure which one to go for, been reading about the DS and im not sure if it or the Power programmer is better? Anyone with a 03 able to shed some light?
#826
I`m needing a tuner cause my truck is bogging down when going up a hill with OD on, the local repair shop tells me they think its my tires, i`m using 32s and on straights its fine but up a hill it bogs down real bad. Anyone else know the cause?
#827
Getting a tuner is the first thing you want to do. Then move from from there. For you with an 03 I would get the Superchips 3865 and the Diablo on an 03 will do you no good.
#828
Spoke to Diablo yesterday and they told me that have no idea why I only got the 87 and 93 tunes, but not the 91. But, they said they only difference between the 91 and 93 tunes was 2* of timing and I can load the 93 tune but change it 2*. How do I do that?? Thanks.
#830
Yeah, I was looking at the Diablo and did`nt find any that would even work with my 03 lol, far as the SC 3865, i`m looking into it! Any idea as to what could cause it to bog down? A friend at work has the same model as mine if I remember right and hers is a ext cab and she said hers does`nt have any trouble at all. This kinda worries me. Also, if it matters, it has a K&N air intake system on it as well as a flowmaster, it had this on it when i bought it, far as I know thats all it has extra.
