Gear swap progress
Old Feb 26, 2011 | 07:35 PM
  #81
chambers's Avatar
chambers
I'll bring you mine for a rebuild if it ever craps out on me, you should know everything about this when you're finished.
Old Feb 26, 2011 | 11:00 PM
  #82
areinike's Avatar
areinike
I'm sayin' man ...
Old Feb 27, 2011 | 11:46 AM
  #83
areinike's Avatar
areinike
Damn, forgot to put races in the freezer last night ... well, looks like I'm on hold for a couple of hours.
Old Feb 27, 2011 | 12:03 PM
  #84
DukesOfHazzard's Avatar
DukesOfHazzard
read all your pages and your persistent i would of gave up and went to a drivetrain specific shop and said here ya go do what you gotta do and pay the bill. But you have to learn somehow goodluck again .maybe no wobbly pops this time j/k lol
Old Feb 27, 2011 | 12:52 PM
  #85
areinike's Avatar
areinike
I've been pretty persistent because I haven't been able to find any shops that specifically admits to knowing the ins and outs of these rears. I've pretty much got it under control now with knowledge I've gained here and there but nothing beats trial and error with experience. I've taken this thing apart a half a dozen times so the experience part, I've pretty much got that one down! I was very close last time, just had a pinion bearing too tight it seems. Learn from my mistakes! Wobbly Pops! love it.
Old Feb 27, 2011 | 07:39 PM
  #86
areinike's Avatar
areinike
Ran out of daylight ... testing that Ratech solid spacer ... unfortunately, it didn't work out. Ended up using crush sleeve after all. Just could not get that right amount of rotational torque using the Ratech. 0.604 was too tight and 0.606 was too loose - no in between ... the only right way is to use the crush sleeve. So I got the pinion bearing in at about 22 in./lbs. of rotational torque before I ran out of daylight ... so on to tomorrow!
Old Feb 27, 2011 | 07:41 PM
  #87
areinike's Avatar
areinike
Here is what the solid spacer looks like by the way ... didn't use it, just FYI ..
Old Feb 27, 2011 | 07:43 PM
  #88
areinike's Avatar
areinike
In case you didn't notice, here's races out ...
And new races in ...
Putting them in the freezer definitely helps ... try to put them in overnight.
Old Feb 28, 2011 | 04:07 PM
  #89
areinike's Avatar
areinike
All done ... again. Total rotational torque ended up being 35 in./lbs including carrier and backlash adjusters torqued to 75 ft/lbs. I didn't intentionality set them that way, it's just that, that was the most I'd go and I still have smooth rotational torque. All new bearings so I'm sure when they break in, it'll turn easier.
Ended up setting backlash to 0.0095. For some reason, that's what it set at and I decided "what the heck" and check patterns and they were dead center all around. I like having a wider backlash to help with cooling. We'll see. First road trip ended in 120*F versus 140*F to 150*F I've seen. Time will tell. Didn't drive it but for 10 minutes. So, there's your update!
Old Feb 28, 2011 | 05:48 PM
  #90
chambers's Avatar
chambers
Much cooler than before, was it at similar speeds and conditions as the other times you checked?
