Nav/radio display doesn't work
I know everyone is going to say do a search. Well I did using every term I could think of and couldn't get a hit soooo..... My problem is that once it gets cooler out, the display on my radio/cd/nav player doesn't light up. When this happens, none of the control buttons will work. It will be stuck on whatever station or function it was on previously. There are times when it will eventually come on after about 30 min. Then everything works fine. Other times it will take way longer. In the summer, it will come on within 2 min. Dealer said I have to replace the unit. I don't have $1600 to just spend on a radio. There has to be a fix since it is a random problem. This is an OEM radio, by the way. 2004 Dodge Ram 2500 diesel.
![Icon Rant](https://dodgeforum.com/forum/images/smilies/icon_rant.gif)
I know everyone is going to say do a search. Well I did using every term I could think of and couldn't get a hit soooo..... My problem is that once it gets cooler out, the display on my radio/cd/nav player doesn't light up. When this happens, none of the control buttons will work. It will be stuck on whatever station or function it was on previously. There are times when it will eventually come on after about 30 min. Then everything works fine. Other times it will take way longer. In the summer, it will come on within 2 min. Dealer said I have to replace the unit. I don't have $1600 to just spend on a radio. There has to be a fix since it is a random problem. This is an OEM radio, by the way. 2004 Dodge Ram 2500 diesel.![Icon Rant](https://dodgeforum.com/forum/images/smilies/icon_rant.gif)
Well if you already have a double din radio in your truck then you should be able to go to a local audio shop and get a new double din and it will fit. An aftermarket double din radio will cost anywhere from $400-$800 bucks depending on if you want to keep navigation/bluetooth/etc.
Yes the orange wire control illumination. However if it works some times then doesn't work other times I don't see how 1 wire can be the problem. It's not very hard to pull the radio out, you might as well go ahead and check all the wires.
Trending Topics
These rams are a pain to get at the radio as far as I know. Take apart the whole central dash. Lol.
My old Nissan pickup had like 2 screws. Now that was easy.
And my cd player doesn't really work past -30 Celsius, which has been a lot lately. Luckily the radio still functions.
Ok, just for ****s and giggles, does anybody know of any aftermarket double din radios that will fit exact to the bezel and mounts? Looking for an AM/FM, Sat, Nav, and 6 player cd combo unit. I can't see spending $1600 for a factory unit. Can't see spending that much for any radio period.
