3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok, I realize how stupid I am. With that bieng said, me and my buddy were messing around and hooked up a nitrous line with no jet on it into my intake, the plan was to barely open up the bottle too see how it reacted. Well he opened it up too much and we were probably running a 500hp shot for about 4 sec before the engine died.
We are about to start pulling stuff apart starting with the plugs to see if maybe they are just fouled.
It still cranks over and seems like it has compression so I dont think I through a rod.
My question is, is there anyway for the dealership to prove that I was spraying? or can i possibly have it fixed under warranty if I came up with a good story, Ive actually done it before with stuff that was my fault on my old nissan.
Where are you injecting the NOS? Did you have to tap into the air intake or use a plate?
Just hitting it once will not show any signs of use. It does keep the pistons clean with continuous use. At least it did in my Mustang
Damn, yeah I bet those four seconds were amazing. But like everyone else has said posting it on here is NOT a smart idea. I would delete it as soon as possible. You should be fine, I dont beleive there would be any signs of the actual reason it stopped working
