Squeaking After a Leveling a 2008 Ram
Me and my brother installed a 2.5 in leveling kit on my truck a couple of days ago and now the front end of my truck squeaks. The squeaking seems to be coming from the front suspension and it is very high pitch. It doesn't just squeak from time to time neither, it is almost nonstop. When we were installing the spacer we couldn't get the tie rod off on either side so we worked the spring in. We did try very hard to get the tie rod off by trying to loosen the ball joint. In this process my brother sprayed penetrating oil in the ball joints and I am not sure if that would break down the grease in them. Another another thing I was thinking that could have caused the problem might be that my brother insisted that we didn't need to torque the nuts to spec, he just hit them with his impact wrench so I really don't know how tight the nuts are. Thanks for your help in advance and ask me any questions that you might have.
Trending Topics
Hmm the spring should not be moving enough to move, as you noticed it's under a little bit of tension...my thoughts are youdidnt set the spring back in right....is the end of the spring in the little notch on the 0900 position of the bottom spring bucket(looking forward)??
Mine squeaks a little off road...and it's a poly spacer! Did you do the alignment and longer shocks? Also, are you having the UCA hit the top spring bucket at all?
I'm saying that thinking you have a 2wd of course
When I did my level kit, I called a buddy of mine who works for Pro Comps R&D facility to see if there were any "tricks of the trade" that I should do when I install it.Besides the usual stuff that I already knew,He said now this might sound a little stupid.But He said to grease the top & the bottom of the spring with bearing grease.Not a whole lot.but just enough to get a good coat on it.If you don't your going to get the dreaded spring squeak. Because the spring is under more pressure than it was,And it moves alot more than you think it does.I didn't belive him and didn't grease them at all.Sure enough,My front springs squeaked all the time.And I mean the ear piercing blood curdling squeak!.I eventually took them back out and greased them up.Now the squeak is gone,And it doesn't sound like my truck has a family of rats in it anymore.
