Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Dec 11, 2011 | 12:01 AM
  #321
Plainbroke's Avatar
Plainbroke
Default Can I put HIDs in these headlighs
I have these headlights http://www.slickcar.com/details/4093...headlights.asp in my truck can I put HIDs in the High and low projector beams ???
Hope this hasn't be asked before, I looked but not real good at this search function..
Old Dec 11, 2011 | 12:51 AM
  #322
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can install them ut the light output will generally be chit because those are halogen projectors and not HID projectors
https://skydrive.live.com/?cid=fb87b...6FBFBF4%211038
https://skydrive.live.com/?cid=fb87b...96FBFBF4%21333
Old Dec 12, 2011 | 06:50 PM
  #323
06Dak4.7Silver's Avatar
06Dak4.7Silver
2006 Dodge Dakota - I bought the CANBUS kit from HIDExtra on Black Friday
I installed the kit and the lights work fine (35w ballasts, 8k, etc..). However, once I turn off my lights or flash my high beams (halogen high) my low beams will not come back on..After I let the truck sit for a few minutes they will come back on again when I turn the switch and stay on. They work great for me and I love them but my problem is I can't shut them off because then I have no lights for atleast 10 minutes. Its like once the ecm goes into sleep mode and everything shuts off they will activate again. I bought capacitors from the same vendor to try to fix the problem (they actually recommended capacitors but said a relay was optional). Plugged those in Saturday and I have the same problem..nothing changed. Any ideas?
Old Dec 13, 2011 | 10:12 AM
  #324
jwhirl06's Avatar
jwhirl06
So I just recieved my 35w CANBUS HID kit from newegg, no relay harness included even though it said it did. I'm guessing I'm gonna need this before I even bother with the install, or can I temporarily run them without till the mfr sends me one.
Old Dec 14, 2011 | 10:57 PM
  #325
Plainbroke's Avatar
Plainbroke
Darn Weedahoe Not what I was hoping to hear...
Old Dec 14, 2011 | 11:07 PM
  #326
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know man. There have been guys who have done it but from all I've read of there feedback, they didn't like it.
Again, there have been some who went ahead and wired them straight to the OEM wiring and it worked but i like throwing fact of having a harness so the relay takes the load and not the OEM wiring.
But if you think about the HIDs we put on our fogs, they don't have a harness.
Old Dec 17, 2011 | 10:28 PM
  #327
dirtydog's Avatar
dirtydog
Moderate User
I used a relay kit for my fog hid's! They did work fine hooked straight up, but the start-up current isn't good for any of the OEM connectors(i.e.headlight switch,tipm,cluster.etc)
Old Dec 18, 2011 | 12:36 AM
  #328
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah well see......uh.......I aint got those TIPM issues....LOL
Although i do agree the startup voltage is high and should be carried by a relay
Old Dec 18, 2011 | 10:29 AM
  #329
Catchin Zs's Avatar
Catchin Zs
I have a low beam HID kit with fogs too. The other night I went out, parked it for a little while,fired it up again and cut the lights on ( I have the low beams and fogs wired to the fog button) and nothing came on.. have had these working for 3 weeks until now. Thinking it is a blown fuse or a relay. Any insight?
Old Dec 18, 2011 | 11:15 AM
  #330
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why would you wire low beams and fogs to the fog switch? And yes nothing working means no power so i would start with the fuse and then wiring.
