Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old May 29, 2013 | 05:32 PM
  #631
Mike O'Brien's Avatar
Mike O'Brien
the kit is bi xenon and i used all four resistors im gonna go back and just cut and cap them in. i thik it might be the stupid lil wire taps that are throwing it out of wack. other than that any thoughts? and or soes anyone have a diagram i can follow?
Old May 29, 2013 | 07:30 PM
  #632
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed. Solder over t-taps. 100% the way to go
Old Jul 26, 2013 | 10:36 PM
  #633
mnsherick's Avatar
mnsherick
Passenger side headaches...
Ok, so about 2 years ago I installed HID projector fixtures. After a few months I started to have trouble, first one light would not come on then the other. After I found this thread I installed the 50w resistors and no more issues.
Now about 3 months ago my pass. side light stops working, I checked bulbs/ballast all checks out OK. Here is the weird thing.
I can turn on the head lights and they work fine, once I start the truck the pass side turns off and wont turn back on. If I let the circuit 'rest' for 3hrs or so I can turn on both head lights again.
I've also noticed that if I start the truck, then turn of the head lights they seem to work 85% of the time.
Any tips?
-Matt
Old Jul 26, 2013 | 10:38 PM
  #634
weedahoe's Avatar
weedahoe
Hall of Fame Member
Common for with key off/lights on that they will work but with key on/lights on they will not. Check your 50 watt load resistors and connections on the side.
Old Aug 10, 2013 | 03:28 PM
  #635
cr8zynelly's Avatar
cr8zynelly
So I have the Bi-Xenon kit and it has 2 resistors per side. . .thats what you mean when your talking about 4 resistors, right? Please help I'm about to install now.
Old Aug 10, 2013 | 04:24 PM
  #636
weedahoe's Avatar
weedahoe
Hall of Fame Member
Correct. Bi-Xenon = (4) 50 watt load resistors. 2 per side. One on low beam wire, the other on high beam wire
Old Dec 14, 2013 | 06:32 PM
  #637
carrigan_shane's Avatar
carrigan_shane
Default Hid turn on and off
Hey I have a 2007 dodge ram with aftermarket headlights in it. They are now a H3 for lowbeam n H1 for highbeam . I put a hid set in for my low beam only and they both keep going on and off. I got a new ballast with a higher resistance . It sovled the problem for a night. Now both keep going on and off. The driver side will stay on and the passenger side will keep going on and off then when I turn my light off then back on tge driver side will go on and off then both will go off and come back on then go on and off
what can I do to stop this.
and also my radio works fine but if I got my satellite radio on its all static.
And iam got a set of hids for my foglights but iam holding off till I get my low beams staying on
Any information would be great
thanks
shane
Old Dec 14, 2013 | 06:43 PM
  #638
weedahoe's Avatar
weedahoe
Hall of Fame Member
thanks
shane
shane, welcome to the site.
Please go back and read the first page and purchase the correct accessories to go with your HID set to make them work correctly. Ballasts do not provide resistance. Load resistors provide resistance.
As for static problems. This is common and typically of cheap ballasts which do not shield their EMF/EFI and in turn broadcast it to where the vehicles antenna pick it up. You can try other grounds and you can also try relocating them
Old Dec 14, 2013 | 07:15 PM
  #639
carrigan_shane
Perfect thanks for you advise
Old Dec 14, 2013 | 07:18 PM
  #640
weedahoe's Avatar
weedahoe
Hall of Fame Member
Never a problem. We love to help. Stick around and see some of the wild and crazy things guys do to their rides. It might give you some ideas
