Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 1, 2014 | 10:43 AM
  #731
weedahoe's Avatar
weedahoe
Hall of Fame Member
Correc. Black wires to ground
Old Aug 1, 2014 | 10:46 AM
  #732
FreezLe223's Avatar
FreezLe223
Thank you for all the Helo weed you have really worked with me and be generous with your knowledge!
Old Aug 1, 2014 | 10:49 AM
  #733
FreezLe223's Avatar
FreezLe223
So blue clip goes into wiring harness and then i ground resistor and put the other 9006 male end into the ballast correct?
Old Aug 1, 2014 | 10:50 AM
  #734
weedahoe's Avatar
weedahoe
Hall of Fame Member
Correct on the install and connections. No problem on the help. It's what we are here for.
Old Aug 1, 2014 | 06:06 PM
  #735
RamRod37's Avatar
RamRod37
Originally Posted by FreezLe223
How many would i need for a single HID low beam kit?
you need 2- 6ohm 50 watt resistors for low beam
And Sorry About this post IE loaded My Page Wrong some How it loaded the wrong page as being the last page and I replied to A Topic That's already been answered There was multiple post before I qot to respond that's why my response was for two pages back oops I forgot no new notifications are given till first one loads sorry for that
Anyway Since the post is here now watch buying PNP Resistor Harnesses I did the same thing trying to save a few minute time wiring the resistors in and the dang harness I purchased was wired wrong had to rewire them both
Old Aug 1, 2014 | 06:49 PM
  #736
FreezLe223's Avatar
FreezLe223
i ordered these off ebay, i will let everyone know how they work for my 55w hids. i just plug my relay harness into the kit, ground the resistor and connect the male side to female ballast and it should fix HOPEFULLY!
http://www.ebay.com/itm/2-X-Car-HID-Xenon-Stop-Flicker-Canbus-Warning-Canceller-Decoder-Resistor-H13-/221309498879?pt=Motors_Car_Truck_Parts_Accessories&hash=item338712f5ff&vxp=mtr
Old Aug 2, 2014 | 01:47 PM
  #737
masboy's Avatar
masboy
so will buying a 55w HID kit + relay harness is better option ? seems like the problem happened because 35w hid kit.
Old Aug 2, 2014 | 02:18 PM
  #738
weedahoe's Avatar
weedahoe
Hall of Fame Member
Power output of the ballasts has nothing to do with it. You guys need to read the first page and see why HIDs themselves cause this issue versus halogen. Wattage is irrelevant
Old Aug 3, 2014 | 02:46 AM
  #739
ffsag's Avatar
ffsag
Where the resistors are supposed to hook up ?? In the relay harness or in the oem wiring ?
Old Aug 3, 2014 | 05:46 AM
  #740
RamRod37's Avatar
RamRod37
From the low beam + to negative- between relay and oem harness in the relay harness is a good place cause it keeps you from having to alter your factory harness
