Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 4, 2014 | 05:50 PM
  #751
ffsag's Avatar
ffsag
Originally Posted by weedahoe
HIDs are flashing because relay is clicking. Relay is clicking because power to the relay which comes from the OEM headlight plug is being cut off. Power is being cut off because PCM doesn't see a load thus the need for the load resistors.
Check your connections and try again
Do you recommend to use 4 resistors for a low beam application ?
Old Aug 4, 2014 | 08:50 PM
  #752
weedahoe's Avatar
weedahoe
Hall of Fame Member
Xenon = HID low/halogen high = (2) 50 watt load resistors
Bixenon = HID low/high = (4) 50 watt load resistors
What connectors are you using to tie them in place? Solder and heatstrink would be all I would use
Old Aug 4, 2014 | 09:23 PM
  #753
ffsag's Avatar
ffsag
I will redo it correctly tommorrow with solder and heatstrink.
Old Aug 5, 2014 | 09:19 PM
  #754
ffsag's Avatar
ffsag
Everything is right in place (I think), I welded both resistor and they keep firing randomly. Any suggestions ?? Is a bad battery could cause this issue ?
Old Aug 5, 2014 | 09:31 PM
  #755
weedahoe's Avatar
weedahoe
Hall of Fame Member
With the key on/engine off, do they flash?
With the key on /engine on, do they flash?
Old Aug 5, 2014 | 09:36 PM
  #756
ffsag's Avatar
ffsag
With the key on/engine off, do they flash? No flash at all
With the key on /engine on, do they flash? Yes it flash but not really like a flickering more like a shutting down.
Old Aug 5, 2014 | 09:49 PM
  #757
weedahoe's Avatar
weedahoe
Hall of Fame Member
Key on/engine off = No PCM detection
Key on/engine on = PCM trying to detect bulbs
While you can use a meter to test the resistors for proper resistance, it still sounds like you either have a bad connection or do not have them connected properly
Old Aug 5, 2014 | 09:58 PM
  #758
ffsag's Avatar
ffsag
Thanks for your patience. I will try, later this week, to hook them up to the relay harness instead of the oem wiring. Maybe that will change something ...
Old Aug 5, 2014 | 10:54 PM
  #759
RamRod37's Avatar
RamRod37
ok are your hooking one end of resistor to the ground and the other to the low or If a Bi kit To low/high Positive wires that should have fixed the Issue
Old Aug 6, 2014 | 07:38 AM
  #760
ffsag's Avatar
ffsag
Exactly what I did.
