3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The Little Woman has an '06 1500 Ram 4x4 with a Hemi in it. Any one out there more familiar with these engines than I am have the hot setup on brand of plug and heat range that will compliment... milage and occaisional towing at 5000 ft in Nevada.
Champion coppers work great. Part #570. I agree with dirty's 40k recommendation; plugs still look good at 30k, but definite wear at 50k. I noticed difference with wire change at 60k also.
Ditto on standard champ coppers. Made the mistake once running double platniums. Truck ran great for 10k. Then random misfires. Replaced with coppers go to go no more issues.
Yep, standard (cheap) coppers do fine. Have personally seen a Hemi run like total crap on a brand new set of Bosch Platinum plugs and then run like a top after helping the owner change out to Champion Coppers. Standard NGKs would also be a great choice...
Also got great results with sticking to the coppers. Don't let the parts guy try and convince you that they are no good for your hemi
Couldn't agree with this more. The guy at AAP tried to get me to buy iridiums and tried telling me they were the stock plug from the factory. Had i nor known better I would have believed him but I took my business to Autozone and they knew the stock plug was the copper Champion.
Thanks, Mike
My 06 had 50,000 miles on the originals, and still looked good. I put autolite double platinums in when I changed and now have 106,000 miles with never a miss and still running perfectly. I drive mostly interstate
Ditto... I tried the Bosch Platinum, Irridium and with both my 03 1500 Hemi ran like S**t
Only when I put the Champion standard heat range coppers did it run like a CHAMP!
NO complants here, especially when you gotta buy 16 of those little suckers!
